brakes, Brakes and BRAKES, Bigger is better |
Bigbohr |
Dec 17 2004, 05:37 PM
Superlurker Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 |
The size difference was so striking that I had to post a pic ...
On the left is a 914 front caliper, in the middle a 911SC front caliper and on the right a 944 Turbo front caliper. The 944 caliper can be modified to fit 911 struts. Despite its larger size, the 944 caliper seems to weigh significantly less than the 911 A caliper. I guess an S caliper may be lighter. Other advantage of the 944 caliper is that it is a 4 piston design. Attached image(s) |
seanery |
Dec 18 2004, 07:06 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
If I remember correctly this is what I've got on bluecar:
FRONT: 944 Turbo front calipers on 911S Bilstein struts Carrera Front Rotors REAR: Boxster monobloc rear calipers Rich Johnson adapters 911 SC Rear Rotors Weltmeister adjustable Prop valve |
Lo-Fi Version | Time is now: 7th June 2024 - 02:50 AM |
