> 914World Classifieds Rules
> WTB: Oil Cooler Hardware, Prefer Derale
rbzymek
post Aug 7 2020, 06:46 PM
The oil temperature is on my 2056 is getting very close to the red zone with even moderate driving on an 80 degree day. I plan to use a Sandwich oil filter adapter type system.
The parts I prefer are:
Derale Atomic Cool DER-15950 Plate and Fan
along with
Derale Temperature controlled Sandwich Adapter DER-15702
What do you have in your spares pile?
Thanks in advance,
Ray
rbzymek
post Aug 9 2020, 01:49 PM
So I checked the thermostat and it appears to be working as designed.
Here it is cold.
Here it is hot.
'Attached Image
I also checked the timing and it was about 20 Deg BTDT instead of 28 Deg BTDC due to point wear. (Need to install the Petronix on the shelf.) Reset the timing ans saw no temp improvement.
I still cruise at 55 in 5th and see the following on the gauge:
If I get on it I can push it to the red zone on a 80 degree day. I still need to make sure I have the correct sender. I still have the original 1.8 engine so I can use the old sender if needed.
If the sender is correct I think I need an oil cooler so still looking for parts in case it goes that way.
barefoot
post Aug 10 2020, 01:49 PM
QUOTE(rbzymek @ Aug 9 2020, 03:49 PM) *
The 75-76 without center console used a temp gauge built into the combo gage. the red zone is way further right. That's my gauge and indicator never gets past mid point. Pretty sure I've got the correct sender.
- Lo-Fi Version Time is now: 16th June 2024 - 09:09 PM
