| porschetub |
Aug 8 2020, 07:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,200 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As per question,TIA
| porschetub |
Aug 11 2020, 01:42 PM
Thanks guys,my reason for removing it was the change the inner oil seal as that was clearly where it was leaking.
Would like to have machined for a second o ring but have no lathe to do it on as my brother is away so couldn't use his workshop. Checked it this morning and no leaks so forever hopeful (IMG:style_emoticons/default/biggrin.gif) . |
porschetub Speedo angle drive oil seal removal Aug 8 2020, 07:11 PM
bdstone914 @porschetub
Carve out the inner lip with a knife... Aug 8 2020, 07:49 PM
porschetub
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 8 2020, 09:58 PM
Mikey914 If the drive is out you can get behind it easy eno... Aug 9 2020, 01:24 AM
Frankvw listen, there is a very easy trick to get it out. ... Aug 9 2020, 04:01 AM
Tdskip
listen, there is a very easy trick to get it out.... Aug 9 2020, 05:56 AM
porschetub Saga continues,found a fair amount of wear on the ... Aug 10 2020, 05:33 PM
Note the erosion on the aluminum wea... Aug 10 2020, 10:01 PM
Mikey914 Your more likely to have fluid leak at the worn se... Aug 10 2020, 09:28 PM
porschetub Topped off the trans only a small amount to top sp... Aug 12 2020, 11:20 PM
Frankvw porschetub, you asked for comments, here mine:
... Aug 13 2020, 01:24 AM
porschetub
... Aug 13 2020, 03:01 PM
brian minson I had to replace the seal on mine a few months bac... Aug 13 2020, 04:06 PM
porschetub
I had to replace the seal on mine a few months ba... Aug 20 2020, 06:48 PM
porschetub Continuing on or "while you are in there... Aug 24 2020, 07:15 PM
porschetub
Continuing on or "while you are in there... Aug 26 2020, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 09:19 AM |
