| simonjb |
Aug 11 2020, 09:23 PM
KiwiMan ![]() ![]() ![]() Group: Members Posts: 574 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States
Forgiven me if a stupid q....
I am re-building my 1974 2.0 and following the manuals and Raby video. As I measure the deck height, I am too close - about .15” I have some spacers, but it appears they only fit correctly on the head side and not on the case side of the barrel. They are too small if I try to install between the barrel and the case. I am using AA pistons and 96 size Is it ok to add the spacers on top of the barrel instead of below to add the necessary height? ![]() |
| iankarr |
Aug 12 2020, 11:19 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Easier to have less than more, for sure.
Since I've now been through two 2056 builds with AA pistons and jugs where the deck height out of the box is over .070, I'm wondering if maybe you got a new (better) set of castings...or if the rig you're using to measure is giving different readings. How exactly are you measuring DH? |
simonjb Piston barrel spacers Aug 11 2020, 09:23 PM
iankarr The general consensus is no. Whether or not head ... Aug 11 2020, 09:31 PM
iankarr Here's a link to EMW's site for shims...
... Aug 11 2020, 09:36 PM
Superhawk996
I am re-building my 1974 2.0 and following the ... Aug 12 2020, 07:28 AM
Superhawk996
I am re-building my 1974 2.0 and following the ... Aug 12 2020, 08:42 AM
porschetub
I am re-building my 1974 2.0 and following the... Aug 12 2020, 07:36 PM
simonjb sorry...I meant .015 !!!!! Tha... Aug 12 2020, 11:10 AM
wndsrfr When you do order the shims, my advice from experi... Aug 12 2020, 07:02 PM
jsaum How did you adjust the deck height for .070? Aug 12 2020, 03:20 PM
iankarr That’s just the way it came up with the AA pisto... Aug 12 2020, 03:52 PM
simonjb So I tried again tonight and also installed the st... Aug 12 2020, 06:46 PM
type2man European motor works has what you need. Or you cou... Aug 12 2020, 06:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
