> Rear Trunk Release, Electric Trunk Release Not Working
GAT
post Aug 13 2020, 03:36 PM
Have a 1973 914 that someone installed an electric rear trunk release. It was always a problem; you had to energize the solenoid by the pushbutton and while energized push down on the trunk lid. Now it does not operate at all; no sound from the solenoid when the pushbutton is depressed. Is there a way to open the rear trunk lid manually?
VegasRacer
post Aug 13 2020, 03:43 PM
ELVIRA
The old ratchet + lots of extensions should do the trick. Best done with a helper.
- Pop the top latch cups and push them inside the trunk
- Have a helper shine a flashlight trough one of the cup holes onto the rear latch assembly
- Get a ratchet and add enough extensions to get you through the other cup hole all the way back to the rear latch. You may want to use a swivel extension at the end.
- Undo the two bolts that hold the latch to the rear panel
- Done
ValcoOscar
post Aug 13 2020, 03:47 PM
Garage Life
QUOTE(VegasRacer @ Aug 13 2020, 02:43 PM) *
- Done
I agree with John...but check to see if you have a blown fuse first (IMG:style_emoticons/default/idea.gif)
Oscar
fiacra
post Aug 13 2020, 04:01 PM
Person.Woman.Man.Camera.TV. = MCI
QUOTE(ValcoOscar @ Aug 13 2020, 02:47 PM) *
- Done
Oscar
You should also check that the previous owner didn't already install a manual release cord. Can't find it immediately but this was in a previous thread along with pictures (I think) about where to locate this.
- Lo-Fi Version Time is now: 14th March 2026 - 10:54 AM
