| GAT |
Aug 13 2020, 03:36 PM
Newbie ![]() Group: Members Posts: 2 Joined: 13-August 20 From: Orange County, CA Member No.: 24,594 Region Association: Southern California |
Have a 1973 914 that someone installed an electric rear trunk release. It was always a problem; you had to energize the solenoid by the pushbutton and while energized push down on the trunk lid. Now it does not operate at all; no sound from the solenoid when the pushbutton is depressed. Is there a way to open the rear trunk lid manually?
| dr914@autoatlanta.com |
Aug 13 2020, 04:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
hold the lid down while someone pushes the button to see if it will spring then if not but power directly to the wire (should find it in the engine compartment). Usually it is because the hinge pivot bolts need lubrication and or the rear catch and latch need lubrication. If the plunger is not seated into the solenoid far enough, the electromagnet will not grab it. Other than that the easiest way is to drill a very small hold in the middle of the "S" and insert a welding rod to trip the lower catch
Have a 1973 914 that someone installed an electric rear trunk release. It was always a problem; you had to energize the solenoid by the pushbutton and while energized push down on the trunk lid. Now it does not operate at all; no sound from the solenoid when the pushbutton is depressed. Is there a way to open the rear trunk lid manually? |
GAT Rear Trunk Release Aug 13 2020, 03:36 PM
VegasRacer The old ratchet + lots of extensions should do the... Aug 13 2020, 03:43 PM
ValcoOscar
The old ratchet + lots of extensions should do th... Aug 13 2020, 03:47 PM
fiacra
The old ratchet + lots of extensions should do t... Aug 13 2020, 04:01 PM
GAT
The old ratchet + lots of extensions should do th... Aug 19 2020, 12:00 PM
oakdalecurtis Here's a previous thread on the subject. You m... Aug 19 2020, 12:04 PM
VegasRacer
Thank you for the information. What size socket d... Aug 19 2020, 12:42 PM
Nojoah Before you starting cutting, drilling, etc, make s... Aug 13 2020, 04:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 12:38 PM |
