> Speedo angle drive oil seal removal, how do you get the bas#ard out ?????
porschetub
post Aug 8 2020, 07:11 PM
As per question,TIA
brian minson
post Aug 13 2020, 04:06 PM
I had to replace the seal on mine a few months back, made a video on how to do it for anyone else needing some help.
https://youtu.be/I291iN4QKAk
Brian (IMG:style_emoticons/default/smile.gif)
porschetub   Speedo angle drive oil seal removal   Aug 8 2020, 07:11 PM
bdstone914   @porschetub Carve out the inner lip with a knife...   Aug 8 2020, 07:49 PM
porschetub   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 8 2020, 09:58 PM
Mikey914   If the drive is out you can get behind it easy eno...   Aug 9 2020, 01:24 AM
Frankvw   listen, there is a very easy trick to get it out. ...   Aug 9 2020, 04:01 AM
Tdskip   listen, there is a very easy trick to get it out....   Aug 9 2020, 05:56 AM
porschetub   Saga continues,found a fair amount of wear on the ...   Aug 10 2020, 05:33 PM
bdstone914   @porschetub Note the erosion on the aluminum wea...   Aug 10 2020, 10:01 PM
Mikey914   Your more likely to have fluid leak at the worn se...   Aug 10 2020, 09:28 PM
porschetub   Thanks guys,my reason for removing it was the chan...   Aug 11 2020, 01:42 PM
porschetub   Topped off the trans only a small amount to top sp...   Aug 12 2020, 11:20 PM
Frankvw   porschetub, you asked for comments, here mine: ...   Aug 13 2020, 01:24 AM
porschetub   porschetub, you asked for comments, here mine: ...   Aug 13 2020, 03:01 PM
brian minson   I had to replace the seal on mine a few months bac...   Aug 13 2020, 04:06 PM
porschetub   I had to replace the seal on mine a few months ba...   Aug 20 2020, 06:48 PM
porschetub   Continuing on or "while you are in there...   Aug 24 2020, 07:15 PM
porschetub   Continuing on or "while you are in there...   Aug 26 2020, 10:01 PM
- Lo-Fi Version Time is now: 15th November 2026 - 09:19 AM
