| Tdskip |
Aug 16 2020, 07:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,770 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning, hope everybody’s been having a good weekend so far. For a street, non-racing, car at what point do you need to use an alternative clutch/pressure plate to deal with increased engine horsepower?
Anything above a 2056? If need it is Kennedy where to go to for that stuff? Thanks! |
| Steve |
Aug 16 2020, 07:36 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,038 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
When I upgraded to a 3.2 I was forced to install a Kennedy adapter since the flywheel is 9 bolt. I bought the Kennedy adapter and stage 2 clutch directly from Kennedy Engineered Products. Much cheaper than anywhere else. The clutch was noticeably harder to push than stock 2.0, but I got used to it. I now run a 915 with clutch return spring and omega spring, so it’s a much better experience.
Tdskip How much engine horsepower before you need a different clutch/pressure plate set up? Aug 16 2020, 07:25 AM
Steve I installed a 2.0 six flywheel on my 2.7 six conve... Aug 16 2020, 07:31 AM
Tdskip Thanks Steve, very helpful. Aug 16 2020, 10:36 AM
Mark Henry Depends on how hard you are on the clutch, in theo... Aug 16 2020, 11:45 AM
Tdskip Thanks Mark, hope you’re doing well up North.
... Aug 16 2020, 11:49 AM
thelogo
Good morning, hope everybody’s been having a go... Aug 16 2020, 11:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 05:32 PM |
