| Mcraneiowa |
Aug 16 2020, 01:15 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
I’m sure this has been covered before but I was not able to find what exactly was of help. I read in one post I should have about 1/8” of up/down travel on the cable to suggest proper tension. I have adjusted it in and out and everywhere in between to no avail. With the engine running I am not able to put the car into either first or reverse without grinding. I do not see any movement of the clutch housing inside of the tunnel, so I don’t think that is the issue. I have a brand new cable installed and other than trying to get the car to move,, this is far as the cable has been used. I can see the arm pulling in and out on the transaxle as well when depressing the clutch. Anyone have an idea of what I am missing here. Looking for suggestions.
| Mcraneiowa |
Aug 16 2020, 02:21 PM
Double checked shift pattern, both set screws and the fit of socket and ball at tail end of shifter. Everything appears in order. With that said, I know I’m missing something for it not wanting to go into gear while the engine is running.
Mcraneiowa Clutch cable adjustment Aug 16 2020, 01:15 PM
Tdskip
I’m sure this has been covered before but I was... Aug 16 2020, 01:21 PM
Mcraneiowa I am not able to get into either 2nd or 5th. I ha... Aug 16 2020, 01:32 PM
Tdskip
I am not able to get into either 2nd or 5th. I h... Aug 16 2020, 01:34 PM
rhodyguy Which gears can you cleanly engage with the motor ... Aug 16 2020, 01:42 PM
Mcraneiowa I asked my wife to double check as I watched the m... Aug 16 2020, 01:50 PM
wndsrfr
I would think if I had the cable adjusted prope... Aug 16 2020, 07:15 PM
rhodyguy There's a spring loaded plate in the shift lev... Aug 16 2020, 02:03 PM
Mcraneiowa Just to clarify it’s a 1974 1.8 L with a side sh... Aug 16 2020, 02:05 PM
Mcraneiowa So I may be making too large of an adjustment and ... Aug 16 2020, 07:42 PM
Tdskip The clutch and shifter on these is wildly differen... Aug 16 2020, 09:52 PM
Mcraneiowa The only thing that comes to mind is how the cable... Aug 17 2020, 01:48 AM
falcor75 I changed to a new clutch cable this winter and I ... Aug 17 2020, 02:07 AM
ctc911ctc This may be helpful as to what to check to see if ... Aug 17 2020, 06:57 PM
Tdskip Did you get this sorted? Aug 18 2020, 03:56 PM
Mcraneiowa I finally resolved my issue. I believe since thi... Aug 19 2020, 05:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 02:15 AM |
