| SuperSquid |
Aug 15 2020, 10:49 AM
Newbie ![]() Group: Members Posts: 24 Joined: 26-February 20 From: Louisville Kentucky Member No.: 23,972 Region Association: South East States |
I am working on a top-end rebuild and the bottom tins do not fit the new cylinder. So now the tins do not fit, very frustrating.
Do you think I should: 1. Modify the bottom tins to fit? 2. Delete the bottom tin because the new pistons will not need them because they are made out of better materials. 3. Try to find a kit to solve the issue My guess is if the bottom tins do not fit I am going to have additional issues as I finish the rebuild. As always thank you for your advice. |
| SuperSquid |
Aug 16 2020, 07:12 PM
Wow, that looks amazing! Thank you for the advice!
SuperSquid Tin Does Not Fit Aug 15 2020, 10:49 AM
914Sixer Common problem if your using aftermarket cylinders... Aug 15 2020, 11:10 AM
Bleyseng I see you are running the birals so modify the bot... Aug 15 2020, 12:33 PM
SuperSquid Thank you! I am on it. Watch out Dremel hear I... Aug 15 2020, 12:39 PM
Mark Henry You have to have the deflectors to get air passing... Aug 15 2020, 05:18 PM
Mark Henry Sorry for the /6 they are 906 deflector copies, no... Aug 15 2020, 05:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 12:04 AM |
