| Mcraneiowa |
Aug 16 2020, 01:15 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None |
I’m sure this has been covered before but I was not able to find what exactly was of help. I read in one post I should have about 1/8” of up/down travel on the cable to suggest proper tension. I have adjusted it in and out and everywhere in between to no avail. With the engine running I am not able to put the car into either first or reverse without grinding. I do not see any movement of the clutch housing inside of the tunnel, so I don’t think that is the issue. I have a brand new cable installed and other than trying to get the car to move,, this is far as the cable has been used. I can see the arm pulling in and out on the transaxle as well when depressing the clutch. Anyone have an idea of what I am missing here. Looking for suggestions.
| falcor75 |
Aug 17 2020, 02:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
I changed to a new clutch cable this winter and I have it adjusted to where there is no thread showing rearwards of the throwout bearing arm so it needs to be quite tight to function for me but then with cars this old they are all individuals now.
I think you could try this if my brain has woken up yet. Make sure you have space infront of the car, then pull the fuel pump relay or coil to dizzy cable and put it in second gear, depress the clutch, bump the starter briefly...does the car lurch forwards? then you need to tighten the cable more. |
Mcraneiowa Clutch cable adjustment Aug 16 2020, 01:15 PM
Tdskip
I’m sure this has been covered before but I was... Aug 16 2020, 01:21 PM
Mcraneiowa I am not able to get into either 2nd or 5th. I ha... Aug 16 2020, 01:32 PM
Tdskip
I am not able to get into either 2nd or 5th. I h... Aug 16 2020, 01:34 PM
rhodyguy Which gears can you cleanly engage with the motor ... Aug 16 2020, 01:42 PM
Mcraneiowa I asked my wife to double check as I watched the m... Aug 16 2020, 01:50 PM
wndsrfr
I would think if I had the cable adjusted prope... Aug 16 2020, 07:15 PM
rhodyguy There's a spring loaded plate in the shift lev... Aug 16 2020, 02:03 PM
Mcraneiowa Just to clarify it’s a 1974 1.8 L with a side sh... Aug 16 2020, 02:05 PM
Mcraneiowa Double checked shift pattern, both set screws and ... Aug 16 2020, 02:21 PM
Mcraneiowa So I may be making too large of an adjustment and ... Aug 16 2020, 07:42 PM
Tdskip The clutch and shifter on these is wildly differen... Aug 16 2020, 09:52 PM
Mcraneiowa The only thing that comes to mind is how the cable... Aug 17 2020, 01:48 AM
ctc911ctc This may be helpful as to what to check to see if ... Aug 17 2020, 06:57 PM
Tdskip Did you get this sorted? Aug 18 2020, 03:56 PM
Mcraneiowa I finally resolved my issue. I believe since thi... Aug 19 2020, 05:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 02:19 AM |
