| Ansbacher |
Aug 20 2020, 11:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Trying to install my pressure plate on my '74 2.0L . All the bolt holes and indexing pin holes line up, but the indexing pins will not fit into their respective holes- pins are a tiny bit too large for the holes. Is it kosher to file down the pins or drill out the indexing holes a tad? Don't want to muck things up at this point. Need advice. Thanks.
Ansbacher |
| jsaum |
Aug 20 2020, 11:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I wouldn't touch the pins. I would adjust the holes on the pressure plate. How much of a difference is there?
Ansbacher Clutch Install Problem Aug 20 2020, 11:19 AM
Ansbacher
I wouldn't touch the pins. I would adjust the... Aug 20 2020, 11:39 AM
jcd914 :WTF:
The pins normally fit tight into the press... Aug 20 2020, 11:41 AM
jsaum I would get an exact size matched drill bit to the... Aug 20 2020, 11:44 AM
Mike D.
:WTF:
The pins normally fit tight into the pres... Aug 20 2020, 12:01 PM
Ansbacher I solved this by lightly reaming out the indexing ... Aug 20 2020, 03:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 06:46 PM |
