| ctc911ctc |
Aug 20 2020, 05:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,311 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
'74, 2.0 - around 22K miles
Ok, this one i do not understand. After watching Dr Evil's video, I decided to exchange the selector for 2/3 with the selector for 4/5. Though the teeth on the second gear side were still in good shape, I was putting in new dog teeth and thought this to be a good path. Thank you @Dr_Evil So, I break down all of the gears, replace dog teeth on 1st and 2nd. Last thing to do is to swap the selector. I removed the selector from the 4th/5th position and this is what I found. The side that faced 5th gear has NO teeth. They are not worn off, they are evenly flat all of the way around! (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif) The tranny had very mild amounts of metal in the oil, i put a magnet in the oil after it was drained to check. Pretty sure they were not ground down! Fifth gear worked great - never ground or had trouble. The fifth side is FLAT, (above) not a point nor ANY wear where the points should be. The fourth side is perfect (Below). Sharp even teeth with very little wear. Has anyone seen this before? Guess I will need to either buy a 2/3 selector or flip it and hope for the best.......sigh....... Any guidance is welcome..... (IMG:style_emoticons/default/confused24.gif) |
| porschetub |
Aug 20 2020, 06:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,030 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I don't know ,I think transmissions are a some what of a mystery too me,34yrs as a mechanical engineer I have never opened one up.
The OP may not like to hear this but judging by the wear seen perhaps the mileage on this box maybe more than 22K ,several things come to mind ; could have abused by PO, original box changed out due to an issue, replacement box somewhat worn out or close to it, incorrect oil used in replacement box. My car is a case in point,the PO had 2 of them to build one ,my car is documented low mileage of around 50K miles (our government records) but the gearbox has issues,I have found strong evidence to suggest the mileage is correct on most wear parts however some make me think the PO mixed and mismatched worn items off the parts car. Hope this isn't your issue and you get it sorted ,good luck. |
ctc911ctc No Teeth on the 4th/5th Selector Aug 20 2020, 05:07 PM
ctc911ctc Thanks for the post, as an EE this is even more of... Aug 20 2020, 06:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 01:24 PM |
