| ri914 |
Aug 20 2020, 07:20 AM
Member ![]() ![]() Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States
hello 914 experts,
Need some help before I start programming my ecu. I have an LS6 engine and a boxster s transmission. Does anyone know if i can use the vss sensor on the rear of the boxster s transmission? I know there are a few different types of signals or pulses or what that rate is so I can convert it? Thabk you |
| theer |
Aug 20 2020, 08:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
Later 911s had electronic speedos which match the Look of the 914 gauges. The 911 speedo has the pulses per mile stamped on the side of the can.
If the Boxster signal output doesn’t match the speedo, you can get a Vss converter to make it work. Or use a programmable speedo, if you’re going with non-Porsche gauges. Either way, you can use the Boxster signal and use whatever tire size you want. |
| andys |
Aug 21 2020, 08:33 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Later 911s had electronic speedos which match the Look of the 914 gauges. The 911 speedo has the pulses per mile stamped on the side of the can. If the Boxster signal output doesn’t match the speedo, you can get a Vss converter to make it work. Or use a programmable speedo, if you’re going with non-Porsche gauges. Either way, you can use the Boxster signal and use whatever tire size you want. In my case, the Porsche electronic speedo matched up with the Audi 01e VSS; works perfect. For the PCM to bump idle when AC is switched-on, and the radiator fans to off when +40 MPH, I added a GM VSS and reluctor mounted to the CV. Andys |
ri914 LS6 + Boxster S VSS help Aug 20 2020, 07:20 AM
Chris914n6 I don't have Porsche specs, but VW is usually ... Aug 20 2020, 12:43 PM
BIGKAT_83 The speed output to the speedometer on a boxster c... Aug 21 2020, 03:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 07:37 PM |
