| brcacti |
Aug 22 2020, 08:52 AM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, will I need to take the steering wheel off to get the odemeter guage out for repair?
| porschetub |
Aug 22 2020, 05:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,971 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bob most likely the damage was caused by a trip meter reset while moving,replacement gears can be sourced on ebay but that was a while back if I remember they were like $20 +,however if you don't do the work yourself to replace it it can be a reasonably expensive repair if you farm the work out.
Considering the cost of a good used unit replacement may be a better option but you may want to have it read the correct current mileage of your car. What is actually wrong with your gauge?,have you checked the cable as it could be broken internally,you can test that by carefully turning the square drive CCW @ the gauge end and if you feel resistance it is fine,if it continues to turn it is broken. Try that and report back cheers. |
| brcacti |
Aug 22 2020, 05:41 PM
Bob most likely the damage was caused by a trip meter reset while moving,replacement gears can be sourced on ebay but that was a while back if I remember they were like $20 +,however if you don't do the work yourself to replace it it can be a reasonably expensive repair if you farm the work out. Considering the cost of a good used unit replacement may be a better option but you may want to have it read the correct current mileage of your car. What is actually wrong with your gauge?,have you checked the cable as it could be broken internally,you can test that by carefully turning the square drive CCW @ the gauge end and if you feel resistance it is fine,if it continues to turn it is broken. Try that and report back cheers. HELLO, thanks for your input, I turned the reset and it works fine back to zeros the upper dial is stuck on 99502 miles total on car. The cable going into the MPH must be good as the speedometer was working fine. I am assuming that the pot metal gear is loose inside, that is what many say goes wrong with these. |
brcacti 914 Aug 22 2020, 08:52 AM
nditiz1
Hello, will I need to take the steering wheel off... Aug 22 2020, 08:56 AM
Nojoah
Hello, will I need to take the steering wheel off... Aug 22 2020, 09:08 AM
dr914@autoatlanta.com you will also need to free the odometer reset cabl... Aug 22 2020, 09:24 AM
Mark Henry Is there a good how to repair on this?
Looks like... Aug 22 2020, 10:54 AM
Montreal914 Mark, I followed this "how to" a few yea... Aug 22 2020, 11:02 AM
brcacti Hi again, I have taken it out without removing the... Aug 22 2020, 11:12 AM
914sgofast2 That is the trip meter re-set cable for resetting ... Aug 22 2020, 11:17 AM
brcacti Oh oops, YES I think I know exactly where it goes ... Aug 22 2020, 11:29 AM
FlacaProductions Don't attempt to reset the odometer when you... Aug 22 2020, 11:37 AM
brcacti
Don't attempt to reset the odometer when you... Aug 22 2020, 11:40 AM
Nojoah
Don't attempt to reset the odometer when you... Aug 22 2020, 01:04 PM
brcacti
[quote name='brcacti' post='2844974' date='Aug 22... Aug 22 2020, 01:32 PM
dangrouche
Hello, will I need to take the steering wheel off... Aug 22 2020, 04:14 PM
Mark Henry
Bob most likely the damage was caused by a trip ... Aug 22 2020, 06:35 PM
brcacti
[quote name='brcacti' post='2845060' date='Aug 22... Aug 22 2020, 06:37 PM
bbrock I also followed that Pelican article. Mine was th... Aug 22 2020, 05:42 PM
Garland
I also followed that Pelican article. Mine was t... Aug 22 2020, 09:13 PM
brcacti
I also followed that Pelican article. Mine was ... Aug 22 2020, 09:29 PM
bbrock I like DIY stuff AND am a CSOB so I'd say ... Aug 22 2020, 09:49 PM
porschetub
I like DIY stuff AND am a CSOB so I'd say ... Aug 23 2020, 09:18 PM
914forme $50 bucks doesn't even cover the parts, o... Aug 23 2020, 07:10 PM
bbrock
$50 bucks doesn't even cover the parts, ... Aug 23 2020, 08:37 PM
914forme Later units use plastic, and they break apart. Th... Aug 23 2020, 08:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 04:54 AM |
