| brcacti |
Aug 22 2020, 08:52 AM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, will I need to take the steering wheel off to get the odemeter guage out for repair?
| 914forme |
Aug 23 2020, 08:46 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Later units use plastic, and they break apart. Then you get to pull the shaft and spend a bunch of time getting it all aligned and looking correct. Don't forget the gear is not the same size as the old one and then you get to chuck it in the lathe and machine it to the proper specs.
brcacti 914 Aug 22 2020, 08:52 AM
nditiz1
Hello, will I need to take the steering wheel off... Aug 22 2020, 08:56 AM
Nojoah
Hello, will I need to take the steering wheel off... Aug 22 2020, 09:08 AM
dr914@autoatlanta.com you will also need to free the odometer reset cabl... Aug 22 2020, 09:24 AM
Mark Henry Is there a good how to repair on this?
Looks like... Aug 22 2020, 10:54 AM
Montreal914 Mark, I followed this "how to" a few yea... Aug 22 2020, 11:02 AM
brcacti Hi again, I have taken it out without removing the... Aug 22 2020, 11:12 AM
914sgofast2 That is the trip meter re-set cable for resetting ... Aug 22 2020, 11:17 AM
brcacti Oh oops, YES I think I know exactly where it goes ... Aug 22 2020, 11:29 AM
FlacaProductions Don't attempt to reset the odometer when you... Aug 22 2020, 11:37 AM
brcacti
Don't attempt to reset the odometer when you... Aug 22 2020, 11:40 AM
Nojoah
Don't attempt to reset the odometer when you... Aug 22 2020, 01:04 PM
brcacti
[quote name='brcacti' post='2844974' date='Aug 22... Aug 22 2020, 01:32 PM
dangrouche
Hello, will I need to take the steering wheel off... Aug 22 2020, 04:14 PM
porschetub Bob most likely the damage was caused by a trip me... Aug 22 2020, 05:27 PM
brcacti
Bob most likely the damage was caused by a trip m... Aug 22 2020, 05:41 PM
Mark Henry
Bob most likely the damage was caused by a trip ... Aug 22 2020, 06:35 PM
brcacti
[quote name='brcacti' post='2845060' date='Aug 22... Aug 22 2020, 06:37 PM
bbrock I also followed that Pelican article. Mine was th... Aug 22 2020, 05:42 PM
Garland
I also followed that Pelican article. Mine was t... Aug 22 2020, 09:13 PM
brcacti
I also followed that Pelican article. Mine was ... Aug 22 2020, 09:29 PM
bbrock I like DIY stuff AND am a CSOB so I'd say ... Aug 22 2020, 09:49 PM
porschetub
I like DIY stuff AND am a CSOB so I'd say ... Aug 23 2020, 09:18 PM
914forme $50 bucks doesn't even cover the parts, o... Aug 23 2020, 07:10 PM
bbrock
$50 bucks doesn't even cover the parts, ... Aug 23 2020, 08:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 04:54 AM |
