| broomhandle |
Aug 24 2020, 02:26 PM
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
Hello All,
I have had a project 914 since 2009. I have a hard full of 1.7's and 2.0's, I feel I am tired of these.. plus.. the 901 I feel is the downside... from my past ownership of a 914. I have decided to go subaru. On this forum. I see so many, some go 2.0, some go 2.5? Turbo? I am unsure of what combo to look for. It sounds like Turbo motors, need turbo 5spds. which are very hard to find. So is naturally aspirated jus fine? I would think so. I have gotten prices of a non turbo 2.5 from 2005sih at 1500.00... ugh. Do there majority of the sub motors mount to the transaxles? Or anybody in California want to sell a motor/trans? (IMG:style_emoticons/default/smile.gif) I would love a turbo, but I think I am ok with a non turbo... any help? Thoughts? |
| lierofox |
Aug 24 2020, 03:10 PM
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California
I went with an EJ20K (2.0L Turbo from a 1998 JDM Subaru STi) and paired it with the stock side-shifter that was in the car already, I went through an adapter plate made by Kennedy and the transmission bolted right up without issue, though I had to make my own crossmember to mount the engine.
My setup ranks at about a 7/10 on the jank factor, due to having a less-than-ideal shop arrangement while building it (drama that I don't really want to get too much into) but so far over the last few years I've had decent luck pairing the Subaru turbo engine with the stock 901 transmission, save for a heavy clutch pedal due to the extra grippy pressure plate I got. If you don't dial up a turbo Subaru engine much above stock (220-280ish HP), the 901 will, albeit begrudgingly, handle the power. Renegade Hybrids makes a full cradle for mounting the engine and transmission, as well as an adapter plate, they're a more expensive but a much more turn-key solution. The 5MT Subaru transmission can be used if you convert it to 2WD. There's pre-made setups available for doing that, along with instructions for converting it yourself, as well as converting the shifter mechanism over to a cable shifter using a bellcrank mechanism, and adapting the inboard CVs over to adapt to the Subaru output flanges. In terms of Turbo vs NA transmissions, not much difference other than what kinda clutch they use (pull for Turbo, push for NA) and I believe some subtle differences in the gear ratios. As far as turbo vs non-turbo on the engine itself, just about anything modern will have more get-up-and-go compared to any Type IV engine. That said the turbo EJ engines tended to have lower compression ratios (somewhere around the low 8:1 range) to compensate for the boost pressures they ran, 12-18psi depending on the car and how it's set up. 8:1 in a 2 liter engine is pretty abysmal below 3k rpm, but after that the turbo spooling up is like you're pulling back a slingshot. Once it starts making boost, you're at 7k (or 8k in the STi) RPM before you know what's happening. That said I've never experienced an NA Subaru engine in a 914, I only know what my EJ20K feels like. https://www.youtube.com/watch?v=58YY_S53gyE |
broomhandle Subaru Questions. Aug 24 2020, 02:26 PM
rhodyguy If a NA 2.5 will push a legacy wagon, it will push... Aug 24 2020, 02:47 PM
pploco
Hello All,
I have had a project 914 since 2009. ... Aug 24 2020, 02:51 PM
mjrrti
Hello All,
I have had a project 914 since 2009. ... Aug 24 2020, 04:46 PM
Robarabian I have a Broomhandle too in addition to an EJ 20 p... Aug 24 2020, 07:33 PM
broomhandle I have heard the 2.2 is a bullet proof engine. I t... Aug 24 2020, 07:53 PM
JRust Go with an ez30 especially if you are doing normal... Aug 24 2020, 09:57 PM
808 WRX It pretty much comes down to: how much horsepower ... Aug 25 2020, 01:02 AM
broomhandle Does anybody know what the 3.0L? what years? looks... Aug 25 2020, 11:27 AM
mgp4591
Does anybody know what the 3.0L? what years? look... Aug 25 2020, 12:35 PM
Chris914n6 Trans strength isn't a factor. We are 1000 lbs... Aug 25 2020, 04:18 PM
broomhandle
Trans strength isn't a factor. We are 1000 lb... Aug 25 2020, 05:44 PM
partwerks
Trans strength isn't a factor. We are 1000 lb... Oct 18 2022, 08:23 PM
914forme Maybe if you want grunt you should dare I say, loo... Aug 25 2020, 07:28 PM
broomhandle
Maybe if you want grunt you should dare I say, lo... Aug 26 2020, 09:35 AM
914forme
[quote name='914forme' post='2845924' date='Aug 2... Aug 26 2020, 10:48 AM
rhodyguy My experience with the 2.5 Legacy was short lived.... Aug 26 2020, 09:44 AM
VaccaRabite Use the NA 6 for the low end power. Turbos need R... Aug 26 2020, 10:23 AM
Chris914n6 You might want the 3.5L. Problem is it's newer... Aug 26 2020, 12:49 PM
broomhandle thanks guys, I have reached out to 76-914.
as fo... Aug 28 2020, 10:12 AM
pploco The USDM STI 2.5 has the best of both worlds - low... Sep 1 2020, 01:00 PM
Literati914
The USDM STI 2.5 has the best of both worlds - lo... Sep 1 2020, 03:42 PM
lierofox
The USDM STI 2.5 has the best of both worlds - l... Sep 2 2020, 04:23 PM
pploco AVCS makes a big difference in lower RPM torque. T... Sep 8 2020, 10:55 AM
partwerks
AVCS makes a big difference in lower RPM torque. ... Aug 21 2022, 05:22 PM
partwerks
AVCS makes a big difference in lower RPM torque. ... Aug 21 2022, 06:49 PM
VaccaRabite @broomhandle
What did you end up doing, if anyth... Aug 22 2022, 08:08 PM
AZBanks The EJ251 in my son's 2003 Baja developed rod ... Oct 18 2022, 10:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 03:43 PM |
