| rosenfe |
Aug 23 2020, 03:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I plant to clean top,not sand. Any recommendations for spray paint choice in black
| Lucky9146 |
Aug 24 2020, 12:01 AM
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California
Had great results with SEM Trim Black. Cleaned top with Prep-sol, no sanding, no primer, just right over the existing texture that was there. Provides a nice sheen but not shiny.
You must keep a wet edge, which is difficult with a rattle can, but can be done. You will need 2-3 coats. Have received lots of complements on it. Good luck! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
| Nojoah |
Aug 24 2020, 05:46 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Had great results with SEM Trim Black. Cleaned top with Prep-sol, no sanding, no primer, just right over the existing texture that was there. Provides a nice sheen but not shiny. You must keep a wet edge, which is difficult with a rattle can, but can be done. You will need 2-3 coats. Have received lots of complements on it. Good luck! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) I second the SEM trim black. Mine turned out great as well, sprays nicely out of the can. I've also had similar results with the wurth trim black counterpart as well. You should be looking for a satin finish. |
rosenfe Paint for black targa top Aug 23 2020, 03:14 PM
IronHillRestorations Clean it with a strong mix of soap and water a cou... Aug 23 2020, 06:55 PM
StarBear
Clean it with a strong mix of soap and water a co... Dec 3 2022, 09:36 AM
Tdskip Super helpful post as usual, thanks @IronHillRest... Aug 23 2020, 08:48 PM
Tonyooc I sprayed mine with a product called Raptor. You ... Aug 23 2020, 08:59 PM
Montreal914 :popcorn: Aug 23 2020, 09:55 PM
PCH After cleaning, sprayed mine with a rattle can. Us... Aug 23 2020, 11:34 PM
Had great results with SEM Trim Black. Cleaned t... Aug 24 2020, 03:49 PM
930cabman If I recall correctly BBrock did his a year or so ... Dec 3 2022, 10:59 AM
nivekdodge Sem 39144 is the same trim black in qt liquid form... Dec 3 2022, 11:26 PM
IronHillRestorations @StarBear I suggest a stronger detergent than di... Dec 4 2022, 07:20 AM
StarBear
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 4 2022, 08:58 AM
[b]@[url=http://www.914world.com/bbs2/index.php?... Dec 5 2022, 07:19 AM
mlindner I need to paint mine also, but I need to get back ... Dec 5 2022, 08:00 AM
dr914@autoatlanta.com if the top has been sanded smooth, you will have t... Dec 5 2022, 09:03 AM
Root_Werks The top that came with my 914 was so bad, it was t... Dec 5 2022, 10:18 AM
windforfun
I plant to clean top,not sand. Any recommendatio... Dec 5 2022, 07:47 PM
StarBear Refresh done!
Followed suggestions posted her... Dec 12 2022, 01:15 PM
76-914 Looks great! I have that on my "to do... Dec 12 2022, 02:38 PM
StarBear
Looks great! I have that on my "to do... Dec 12 2022, 04:15 PM
76-914
Looks great! I have that on my "to do... Dec 12 2022, 05:24 PM
eric9144 looks great!! :beer2: Dec 12 2022, 05:07 PM
roundtwo All great info plus…
If needing retexture, sugg... Dec 12 2022, 05:49 PM
StarBear No trouble keeping a wet edge with the SEM spray. ... Dec 12 2022, 05:54 PM
IronHillRestorations Nice work!! It looks great! Dec 13 2022, 06:40 AM
Literati914
After cleaning, sprayed mine with a rattle can. [... Dec 13 2022, 09:51 AM
StarBear
After cleaning, sprayed mine with a rattle can. ... Dec 13 2022, 10:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 11:00 PM |
