| porschetub |
Aug 8 2020, 07:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,200 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As per question,TIA
| porschetub |
Aug 24 2020, 07:15 PM
Continuing on or "while you are in there" as they say,no leaks @ speedo drive,moved on to my rear shifter rod...found locking screw on the fwd uni-joint was loose ,kicking myself as I hadn't drilled a detent for the locking screw (IMG:style_emoticons/default/slap.gif) so it was moving around so fixed that.
Just found with all the caked up grease removed from the shifter,genuine cable fitted,and adjustment of cable position has really improved the action,test drive will confirm. Happy with results (IMG:style_emoticons/default/biggrin.gif) . |
porschetub Speedo angle drive oil seal removal Aug 8 2020, 07:11 PM
bdstone914 @porschetub
Carve out the inner lip with a knife... Aug 8 2020, 07:49 PM
porschetub
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 8 2020, 09:58 PM
Mikey914 If the drive is out you can get behind it easy eno... Aug 9 2020, 01:24 AM
Frankvw listen, there is a very easy trick to get it out. ... Aug 9 2020, 04:01 AM
Tdskip
listen, there is a very easy trick to get it out.... Aug 9 2020, 05:56 AM
porschetub Saga continues,found a fair amount of wear on the ... Aug 10 2020, 05:33 PM
Note the erosion on the aluminum wea... Aug 10 2020, 10:01 PM
Mikey914 Your more likely to have fluid leak at the worn se... Aug 10 2020, 09:28 PM
porschetub Thanks guys,my reason for removing it was the chan... Aug 11 2020, 01:42 PM
porschetub Topped off the trans only a small amount to top sp... Aug 12 2020, 11:20 PM
Frankvw porschetub, you asked for comments, here mine:
... Aug 13 2020, 01:24 AM
porschetub
... Aug 13 2020, 03:01 PM
brian minson I had to replace the seal on mine a few months bac... Aug 13 2020, 04:06 PM
porschetub
I had to replace the seal on mine a few months ba... Aug 20 2020, 06:48 PM
porschetub
Continuing on or "while you are in there... Aug 26 2020, 10:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 09:19 AM |
