> Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1
76-914
post Jun 28 2020, 08:36 PM
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
post Aug 24 2020, 09:20 PM
And then there was this Heatwave........There went 3 weeks (IMG:style_emoticons/default/headbang.gif) . On the bright side the cradle is finished sans 2 weld joints and paint. I changed this cradle up a tiny wee bit. If you saw my other build thread you saw that I needed to make a cover in the trunk in order to cover the starter and the clutch slave cylinder. Well, not the entire slave just the actuator arm and the bleed screw. This is the cover on the black conversion.
After talking to Bob aka @BIGKAT83 I discovered there is another Subaru starter that is clocked differently thus avoiding a trunk cut for the starter solenoid. Order a starter for a 2002 Outback w/ the 4 cylinder and standard transmission. Thx Bob. (IMG:style_emoticons/default/beerchug.gif) I also decided to slide the engine forward 1" giving myself the needed clearance for the slave cylinder. I was dead set on the output flanges being centered with the wheel centers on the first conversion. But truthfully the 1" offset is not noticeable. As with the other conversion I cut the top off the actuator arm where the return spring clips on. It's not needed and gives a little more vertical clearance.
This pic show the clearance between the trunk floor and the starter.
One showing the clearance between the trunk and bleeder screw on the slave cylinder. Look closely and you'll see an 1/8" hole drilled into the trunk floor. This is to help locate a 1" access hole that I'll drill. It will receive a snap in plug to cover and allow me to bleed the slave w/o getting beneath the car.
These two show the arm cut down and the clearance.
There is a "whatchamacallit" that holds the steel tubing and Banjo bolt at the slave cylinder. I remove this and straighten the tube a bit. Then loosen the nut and flip it over the top of the transmission so that the flare nut is on the passenger side looking down. Anywhere in this general vicinity is good as it will tie into an AN-3 flex hose.
Roll up a paper towel and twist it into the transmission fill tube. It keeps crap out and shows you where to drill the "access hole". At some point I'll get lazy and abbreviate this as an "A Hole".
And later you have a place for the dipstick to easily pass through the trunk floor. A very small slit at the edge of the carpet is all that is needed. This pic is from the '73 914 conversion but as you can see there is room to relocate the hole 1" forward. Possibly avoiding a slit on the edge of the carpet. No big deal either way.
76-914   Re-Conversion of a '70 914   Jun 28 2020, 08:36 PM
tygaboy   Yaaaa! Can't wait to see this one come (ba...   Jun 28 2020, 09:31 PM
76-914   Yaaaa! Can't wait to see this one come (b...   Jun 30 2020, 04:52 PM
EdwardBlume   Love those Boxster rims. 70 was a good year. I kno...   Jun 28 2020, 09:35 PM
76-914   Love those Boxster rims. 70 was a good year. I kn...   Jun 30 2020, 04:53 PM
76-914   I've seen several requests for cradles in the ...   Jun 30 2020, 05:44 PM
flmont   What are u thinking price wise on that 901 , Than...   Jun 30 2020, 07:02 PM
76-914   What are u thinking price wise on that 901 , Tha...   Jun 30 2020, 07:25 PM
flmont   Sold..! TY   Jun 30 2020, 07:36 PM
76-914   Sold..! TY PM sent   Jun 30 2020, 08:05 PM
flmont   its still the same I did buy 914forme's crad...   Jun 30 2020, 07:40 PM
flmont   I do need to read ChrisH,..posting on the heater c...   Jun 30 2020, 07:44 PM
76-914   OK, back on track. If you plan to use 4130 chromol...   Jul 3 2020, 06:11 PM
tygaboy   METAL!!!! :headbanger: So cool ...   Jul 3 2020, 06:53 PM
76-914   Go ahead and remove your old hardware from the fro...   Jul 3 2020, 07:24 PM
808 WRX   Once it's is secure be sure the section past ...   Jul 6 2020, 01:39 PM
76-914   Once it's is secure be sure the section past...   Jul 6 2020, 09:51 PM
76-914   Now return the piece in place and hold the newly c...   Jul 3 2020, 08:08 PM
Andyrew   :trophy: :popcorn: :welder: Awesome!!...   Jul 6 2020, 01:45 PM
tygaboy   :trophy: :popcorn: :welder: Awesome!...   Jul 6 2020, 02:24 PM
914forme   Love the low tech cradle build. The roll of tap...   Jul 6 2020, 02:32 PM
JRust   Looks great Kent! Love to see the step by step...   Jul 6 2020, 08:40 PM
2mAn   Love it. I could hear the garage cursing because I...   Jul 6 2020, 09:02 PM
76-914   :trophy: :popcorn: :welder: Awesome!...   Jul 6 2020, 10:04 PM
andys   This is what I did for my cradle in case it helps....   Jul 7 2020, 11:24 AM
76-914   This is what I did for my cradle in case it helps...   Jul 7 2020, 12:59 PM
76-914   Round 4; I was able to steal away for 2 hours this...   Jul 7 2020, 09:38 PM
76-914   OK, things are fixing to get wordy so bare with me...   Jul 8 2020, 03:29 PM
76-914   The Poltergeist is back. That last pic isn't s...   Jul 8 2020, 03:37 PM
76-914   Now for the 3/16" reinforcing pieces. This ru...   Jul 8 2020, 03:58 PM
76-914   And this is why I wear an apron when weld...   Jul 8 2020, 04:06 PM
euro911   Looking good, Kent. (subscribed)   Jul 8 2020, 04:32 PM
Andyrew   That looks STOUT! Might be going a bit overboa...   Jul 9 2020, 08:45 AM
76-914   Looking good, Kent. (subscribed) @[url=http://ww...   Jul 9 2020, 08:04 PM
euro911   [quote name='euro911' post='2832137' date='Jul 8 2...   Jul 11 2020, 10:02 PM
rhodyguy   That's a very handsome table you have for your...   Jul 11 2020, 07:03 PM
76-914   That's a very handsome table you have for you...   Jul 12 2020, 12:47 PM
76-914   The steel spacers or bushing stock arrived last we...   Jul 22 2020, 05:27 PM
euro911   You make it look like you know what you're doi...   Jul 22 2020, 06:01 PM
76-914   Now it's time to take this cross member tube a...   Jul 22 2020, 06:32 PM
76-914   Now remove the cradle from the car and place it up...   Jul 22 2020, 07:03 PM
flmont   Man...That is so perfect !!   Jul 23 2020, 01:45 PM
76-914   Man...That is so perfect !! You jinxe...   Aug 2 2020, 12:16 PM
76-914   And then there was this Heatwave........There went...   Aug 24 2020, 09:20 PM
76-914   Oops. I didn't show any pics of the final crad...   Aug 24 2020, 09:28 PM
euro911   Since you drilled holes for the Schroeder valves, ...   Aug 24 2020, 10:12 PM
914forme   :agree: or other coating of your choice. Fluid Fi...   Aug 25 2020, 06:39 AM
ValcoOscar   Kent- :wavebye: I'm here for you if you de...   Aug 25 2020, 09:48 AM
76-914   Kent- :wavebye: I'm here for you if you d...   Aug 25 2020, 05:03 PM
76-914   Since you drilled holes for the Schroeder valves,...   Aug 25 2020, 05:05 PM
76-914   I did get it in primer this morning. Hopefully I c...   Aug 25 2020, 05:10 PM
76-914   Dressed her up with a new coat this morning. I...   Aug 26 2020, 03:00 PM
808 WRX   :cheer: Looking good! :beer2:   Aug 26 2020, 03:22 PM
76-914   Thx, They're like women."They all look go...   Aug 27 2020, 03:14 PM
76-914   So, before the afternoon heat crept in I was able ...   Aug 27 2020, 03:33 PM
rmarx   Great thread! Thank you for posting all the de...   Sep 11 2020, 05:41 PM
76-914   Sorry I'm late getting back to you @rmarx . J...   Sep 16 2020, 05:37 PM
Steve   Impressive skills Kent!! As Ferdinand sai...   Sep 16 2020, 07:05 PM
rnellums   Great work Kent. When I rebuilt my pedal assembly ...   Sep 16 2020, 07:44 PM
mgp4591   Great work Kent. When I rebuilt my pedal assembly...   Sep 17 2020, 10:48 AM
euro911   You master fabricator, you :headbanger:   Sep 17 2020, 12:04 AM
ValcoOscar   Kent- You are officially a WORLDLY MacGyver! ...   Sep 17 2020, 11:24 AM
76-914   Impressive skills Kent!! As Ferdinand sa...   Sep 17 2020, 07:19 PM
76-914   Picking up where I left off. Here is a pic of the ...   Sep 22 2020, 01:48 PM
76-914   And a couple of "finished product" shots...   Sep 22 2020, 01:50 PM
76-914   Half shafts are out. After cut to length & the...   Sep 24 2020, 04:34 PM
76-914   The first thing I did was remove the 4 bolts from ...   Sep 30 2020, 01:26 PM
914Subaru   Kent, This new project is looking good. I was ins...   Oct 1 2020, 07:28 PM
76-914   Kent, This new project is looking good. I was in...   Oct 2 2020, 10:20 AM
Gint   Excellent work Kent! Subscribed @76-914 [q...   Oct 5 2020, 10:05 PM
Montreal914   Nice shifter location. :) How far back from the ...   Oct 1 2020, 09:24 PM
76-914   Nice shifter location. :) How far back from the...   Oct 2 2020, 10:26 AM
76-914   Nice shifter location. :) How far back from the...   Oct 29 2020, 04:27 PM
76-914   The fuel hose arrived this weekend so I was able t...   Oct 5 2020, 06:30 PM
Montreal914   Thank you for the added shifter information. Looki...   Oct 5 2020, 08:34 PM
euro911   Hey, Mike ( @[url=http://www.914world.com/bbs2/ind...   Oct 5 2020, 11:31 PM
Gint   Hey, Mike ( @[url=http://www.914world.com/bbs2/in...   Oct 6 2020, 04:40 PM
76-914   Future   Oct 24 2020, 05:05 PM
76-914   I thought I should post this for any of you guys t...   Oct 26 2020, 09:23 PM
Montreal914   Thank you :beer2: That is very similar to the 91...   Oct 29 2020, 08:47 PM
76-914   It's been a few weeks and only a few items rem...   Nov 9 2020, 06:04 PM
76-914   Then clamp together and weld. I use this term weld...   Nov 9 2020, 06:09 PM
76-914   All of the plumbing is completed and tied in with ...   Nov 9 2020, 06:25 PM
FL 000   No idea how I have missed this thread until now. N...   Nov 9 2020, 06:56 PM
914GTSTI   Thanks for all the great Ideas ! Your the MAN ...   Dec 1 2020, 10:11 PM
Chris H.   Looks great Kent! What size radiator hoses di...   Dec 1 2020, 10:33 PM
76-914   Looks great Kent! What size radiator hoses d...   Dec 2 2020, 04:50 AM
Chris H.   Looks great Kent! What size radiator hoses ...   Dec 2 2020, 01:16 PM
76-914   I have some catching up to do here. I received my ...   Dec 11 2020, 11:56 AM
rhodyguy   Party ON!   Dec 11 2020, 12:08 PM
Mueller   Nice job, might have to borrow a few of your desig...   Dec 11 2020, 02:12 PM
76-914   Thx Mike. Well, I went to way much trouble install...   Dec 25 2020, 05:09 PM
76-914   If it ain't one thing it's two. I've b...   Jan 12 2021, 10:40 AM
BillJ   Very cool build and thanks for sharing it! Ar...   Jan 12 2021, 11:17 AM
76-914   Very cool build and thanks for sharing it! A...   Jan 12 2021, 07:01 PM
rhodyguy   How many turbos on the replacement 6? 2?   Jan 12 2021, 07:06 PM
Chris914n6   I'd check the harness too to make sure that...   Jan 12 2021, 08:46 PM
76-914   I'd check the harness too to make sure that...   Jan 13 2021, 10:21 AM
76-914   Well it's been 5 weeks and I wish I were furth...   Feb 24 2021, 09:10 PM
76-914   So the newest engine runs great, pulls strong and ...   Feb 24 2021, 09:34 PM
- Lo-Fi Version Time is now: 21st November 2026 - 03:20 AM
