> Both turn signal dash lights, flash when the turn signal is used
tradisrad
post Nov 1 2009, 08:44 PM
All exterior lights work properly, but both the dash lights (left and right turn signal) go on when I use my turn signal. I am expecting the left arrow to flash for a left turn and the right arrow for a right turn, but both arrows flash all the time. the car is a 1970. I think I cleaned all the ground points.
Is this a common problem? What is the fix?
thanks
-Rob
Richncherie
post Aug 24 2020, 11:55 PM
For the last few days the green left/right turn signal arrows on the tachometer would flash once or twice then dim when I was signalling a turn. The green right arrow would thus flash a couple of times at "normal" brightness, then kept blinking but dimmed to barely visible. I could hear the relay clicking. Same for left green arrow for left turns. Once the arrow had flashed a couple of times and then proceeded to dim, BOTH the left and right arrows then flashed dimly together! Outside the car, the front an rear turn signal lights worked as expected.
After reading through this forum, I thought I might need a relay from VW bus, but also noted that someone said to check the fuses. The fuses (original fuse box) looked OK, but I removed, checked for corrosion, and reinstalled them just to be thorough. Voila! Back to normal turn signal indicator light operation.
Unlike some of the other comments, the left/right green arrows at tach have always blinked only the left arrow for left signal and only the right for right. BTW a 1972 914.
tradisrad   Both turn signal dash lights   Nov 1 2009, 08:44 PM
flipb   All exterior lights work properly, but both the d...   Nov 1 2009, 08:46 PM
904svo   Make sure all the bulbs are the correct ones, if y...   Nov 1 2009, 09:42 PM
underthetire   I have the same issue with mine. Someone here said...   Nov 1 2009, 10:08 PM
orange914   I have the same issue with mine. Someone here sai...   Nov 1 2009, 11:10 PM
tradisrad   Is it a good thing that I am not alone? Don't ...   Nov 1 2009, 10:13 PM
tat2dphreak   shit, I thought it was the "way it was"....   Nov 1 2009, 11:12 PM
john rogers   Some 914s had but one light in the tach and some h...   Nov 1 2009, 11:27 PM
jetboy   Let us know if replacing the relay is a fix. Mine ...   Nov 2 2009, 04:46 AM
tradisrad   What rust? Well I do have a very small amount in t...   Nov 2 2009, 09:08 AM
rhcb914   I have a 70 and mine has a similar issue. Turn on...   Nov 2 2009, 09:23 AM
type47   If I recall, this may be the way it operates; both...   Nov 2 2009, 09:28 AM
SirAndy   If I recall, this may be the way it operates; bot...   Nov 2 2009, 03:16 PM
underthetire   If I recall, this may be the way it operates; bo...   Nov 2 2009, 03:38 PM
orange914   Yes. Sort of. Early cars should have the indicato...   Nov 2 2009, 07:26 PM
flipb   [quote name='montoya 73 2.0' post='1223878' date=...   Nov 2 2009, 09:52 AM
flipb   And since I like pictures, here are the two leads ...   Nov 2 2009, 10:18 AM
tat2dphreak   hmm. I didn't care before, but now I must look...   Nov 2 2009, 10:33 AM
plas76targa   FWIW - my 72 blinks similar to above - left flashe...   Nov 2 2009, 12:25 PM
Phoenix-MN   FWIW - my 72 blinks similar to above - left flash...   Nov 2 2009, 12:44 PM
SGB   I had the both indicators flashing thing for 15 ye...   Nov 2 2009, 03:02 PM
ConeDodger   I am glad Andy cleared that up... I thought it was...   Nov 2 2009, 03:55 PM
underthetire   I am glad Andy cleared that up... I thought it wa...   Nov 2 2009, 04:00 PM
wobbletop   Mine both flash at once. Always thought it was the...   Nov 2 2009, 03:56 PM
Spoke   Mine both flashed on my 71. Problem was not groun...   Nov 2 2009, 04:09 PM
Rod   Amazing how many people have this problem! .....   Nov 2 2009, 04:31 PM
kenshapiro2002   I went through all of this about a month ago...che...   Nov 2 2009, 06:44 PM
astronomerdave   All exterior lights work properly, but both the d...   Nov 8 2009, 02:11 AM
tradisrad   All exterior lights work properly, but both the ...   Nov 8 2009, 01:13 PM
underthetire   73, late. independant bulbs.   Nov 8 2009, 10:33 AM
tradisrad   I swaped out my trun signal relay and they light u...   Nov 14 2009, 04:24 PM
kenshapiro2002   One prong. I swaped out my trun signal relay an...   Nov 14 2009, 06:18 PM
Toast   Both of mine flash ONLY when I am applying the bra...   Nov 14 2009, 07:48 PM
kenshapiro2002   Betting a new flasher relay would cure it...borrow...   Nov 14 2009, 09:07 PM
celluloid3   I have the same problem... Both of mine flash ON...   Dec 13 2009, 01:30 AM
Richncherie   For the last few days the green left/right turn si...   Aug 24 2020, 11:55 PM
- Lo-Fi Version Time is now: 15th October 2026 - 04:46 PM
