> Debugging stumble on acceleration when warm
solex
post Aug 23 2020, 09:16 AM
On my past few drives the car has been stumbling when I accelerate specifically when warm and in every gear except first, in my 2.0L D-Jet in a 75'
A few of things to note:
- Ground strap at transmission has been cleaned
- Installed a second ground at battery ground point to the engine fan
- New spark plugs Bosch W175T2
- Engine compression 134-145 all cylinders
- Fuel pressure set to 28 psi
- spark plug new wires
- 123 Ignition curve 2 with vacuum advance attached, 10 degrees advance at idle
- Injectors have been rebuilt by Mr. Injector
- All vacuum hoses have been replaced
- AAR is in working order and has been oiled
Not really sure where else to look, the engine idles < 1000 but is not smooth at times jumping +/- ~ 200 RPM
Any advice would be appreciated.
solex
post Aug 26 2020, 09:30 AM
Hey Rob,
I think I may have overstated the hunting idle, I have adjusted the ECU and mixture, it is better then I have seen it in a while.
The problem I have is under acceleration in 2nd and above gears over ~ 1500 RPM. If I maintain speed there is no problem. The is bucking/stumbling when accelerating
solex   Debugging stumble on acceleration when warm   Aug 23 2020, 09:16 AM
wndsrfr   Clean the contact strips on the TPS...   Aug 23 2020, 09:25 AM
rjames   Have you tried adjusting the fuel mixture with the...   Aug 24 2020, 11:04 AM
BeatNavy   Have you tried adjusting the fuel mixture with th...   Aug 26 2020, 09:22 AM
windforfun   I had a similar problem. I found a new TPS & ...   Aug 24 2020, 11:11 AM
solex   Thank you everyone. I just removed the TPS, which...   Aug 25 2020, 10:35 AM
PCH   Looks like the board is worn out. 914 Rubber has n...   Aug 25 2020, 11:12 AM
PCH   DP   Aug 25 2020, 11:14 AM
solex   I saw the new board, looks great and will order on...   Aug 25 2020, 01:23 PM
solex   I reinstalled the TPS and it was still stumbling, ...   Aug 26 2020, 06:28 AM
solex   Hey Rob, I think I may have overstated the huntin...   Aug 26 2020, 09:30 AM
solex   I go the new boards on Friday, 914Rubber has some ...   Aug 30 2020, 07:53 AM
sechszylinder   Hi, did you checked the trigger contacts which a...   Aug 30 2020, 08:35 AM
solex   Hi, did you checked the trigger contacts which ...   Aug 30 2020, 09:40 AM
sechszylinder   [quote name='sechszylinder' post='2847084' date='...   Aug 30 2020, 01:28 PM
rjames   Fuel pressure maybe too low, AFR could be too lean...   Aug 30 2020, 10:16 AM
solex   This evening I did several things in attempt to fu...   Sep 1 2020, 04:37 PM
rjames   This evening I did several things in attempt to f...   Sep 2 2020, 01:54 AM
DRPHIL914   Thank you everyone. I just removed the TPS, whic...   Sep 3 2020, 06:47 AM
solex   I removed the plenum and located a crack on the to...   Sep 5 2020, 03:57 PM
porschetub   :idea: looks like your throttle body gasket isn...   Sep 5 2020, 10:30 PM
solex   The crack exposed... :D and hopefully repaire...   Sep 6 2020, 10:18 AM
porschetub   The crack exposed... :D and hopefully repair...   Sep 6 2020, 10:10 PM
solex   Got everything installed new with new boots betwee...   Sep 7 2020, 01:12 PM
porschetub   Got everything installed new with new boots betwe...   Sep 8 2020, 07:39 PM
solex   Excellent result,my experience with injection al...   Sep 9 2020, 09:20 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:39 PM
