On my past few drives the car has been stumbling when I accelerate specifically when warm and in every gear except first, in my 2.0L D-Jet in a 75'
A few of things to note:
- Ground strap at transmission has been cleaned
- Installed a second ground at battery ground point to the engine fan
- New spark plugs Bosch W175T2
- Engine compression 134-145 all cylinders
- Fuel pressure set to 28 psi
- spark plug new wires
- 123 Ignition curve 2 with vacuum advance attached, 10 degrees advance at idle
- Injectors have been rebuilt by Mr. Injector
- All vacuum hoses have been replaced
- AAR is in working order and has been oiled
Not really sure where else to look, the engine idles < 1000 but is not smooth at times jumping +/- ~ 200 RPM
Any advice would be appreciated.
