Debugging stumble on acceleration when warm |
solex |
Aug 23 2020, 09:16 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
On my past few drives the car has been stumbling when I accelerate specifically when warm and in every gear except first, in my 2.0L D-Jet in a 75'
A few of things to note: - Ground strap at transmission has been cleaned - Installed a second ground at battery ground point to the engine fan - New spark plugs Bosch W175T2 - Engine compression 134-145 all cylinders - Fuel pressure set to 28 psi - spark plug new wires - 123 Ignition curve 2 with vacuum advance attached, 10 degrees advance at idle - Injectors have been rebuilt by Mr. Injector - All vacuum hoses have been replaced - AAR is in working order and has been oiled Not really sure where else to look, the engine idles < 1000 but is not smooth at times jumping +/- ~ 200 RPM Any advice would be appreciated. |
wndsrfr |
Aug 23 2020, 09:25 AM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Clean the contact strips on the TPS...
rjames |
Aug 24 2020, 11:04 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Have you tried adjusting the fuel mixture with the knob on the ECU? Clock-wise a click or two might fix your hunting idle.
Stumble sounds like either your TPS as wndsrfr pointed out, or car is running too lean, which could also explain the hunting idle. |
windforfun |
Aug 24 2020, 11:11 AM
Senior Member Group: Members Posts: 1,783 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I had a similar problem. I found a new TPS & that did the trick.
solex |
Aug 25 2020, 10:35 AM
PCH |
Aug 25 2020, 11:12 AM
Member Group: Members Posts: 140 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
PCH |
Aug 25 2020, 11:14 AM
DP
solex |
Aug 25 2020, 01:23 PM
solex |
Aug 26 2020, 06:28 AM
I reinstalled the TPS and it was still stumbling, I tried adjusting the TPS which made it slightly better but not good enough, I'm surprised because the TPS has < 6000 miles. I purchased it new in the box...
I ordered two boards last night. |
BeatNavy |
Aug 26 2020, 09:22 AM
Have you tried adjusting the fuel mixture with the knob on the ECU? Clock-wise a click or two might fix your hunting idle. Stumble sounds like either your TPS as wndsrfr pointed out, or car is running too lean, which could also explain the hunting idle. (IMG:style_emoticons/default/agree.gif) I think this is where you need to look. Where is the stumble? Immediately coming out of idle? Or at all RPM's on acceleration? Hunting idle is usually a sign of being too lean. Stumbling on acceleration can also be explained by going suddenly too lean (or, more precisely, more air as throttle opens not compensated fast enough by more fuel). If it happens right from idle, enriching your idle mixture could help. Stumbling can also be caused going the other direction (too rich) or in general too big a change in fuel mixture relative to the amount of air the engine is taking in. In your case, I'm betting on lean. The "dirty / worn TPS" situation is often a bucking at steady cruise caused by poor contacts with the traces. If you look at your TPS, you'll see there are also two other contacts that tell the ECU if the change in throttle is acceleration or deceleration. Make sure those are clean as well. You don't have an Air/Fuel gauge do you? |
solex |
Aug 26 2020, 09:30 AM
Hey Rob,
I think I may have overstated the hunting idle, I have adjusted the ECU and mixture, it is better then I have seen it in a while. The problem I have is under acceleration in 2nd and above gears over ~ 1500 RPM. If I maintain speed there is no problem. The is bucking/stumbling when accelerating |
solex |
Aug 30 2020, 07:53 AM
I go the new boards on Friday, 914Rubber has some fast shipping. I redid both of my TPS's and installed one. While it is better I'm still having some stumbling in the 2500 to 3000 RPM range after many adjustments. I checked the timing and it is still at +10 static on the 123 distributor.
Any other suggestions would be appreciated. Thanks so far. |
sechszylinder |
Aug 30 2020, 08:35 AM
Member Group: Members Posts: 247 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
Hi,
did you checked the trigger contacts which are located in the distributor? If the contacts are worn or the whole assembly is not aligned correctly, you will get stumbling under acceleration. Besides that, there are contacts located in the TPS, which signal that the gas pedal has been hit what should result in an enrichment of the mixture. These contacts need to be carefully aligned, to let the ecu differentiate between acceleration and coasting. br Benno |
solex |
Aug 30 2020, 09:40 AM
Hi, did you checked the trigger contacts which are located in the distributor? If the contacts are worn or the whole assembly is not aligned correctly, you will get stumbling under acceleration. Besides that, there are contacts located in the TPS, which signal that the gas pedal has been hit what should result in an enrichment of the mixture. These contacts need to be carefully aligned, to let the ecu differentiate between acceleration and coasting. br Benno Hi Benno, I have a 123 distributor so no trigger points. I adjusted the TPS but had trouble using a Dvm checking resistance and used the continuity to the point that there was no continuity between contacts 17 and 12 fiddling back and forth because of the contact on the posts on the arm of the tps |
rjames |
Aug 30 2020, 10:16 AM
Fuel pressure maybe too low, AFR could be too lean...
sechszylinder |
Aug 30 2020, 01:28 PM
Hi, did you checked the trigger contacts which are located in the distributor? If the contacts are worn or the whole assembly is not aligned correctly, you will get stumbling under acceleration. Besides that, there are contacts located in the TPS, which signal that the gas pedal has been hit what should result in an enrichment of the mixture. These contacts need to be carefully aligned, to let the ecu differentiate between acceleration and coasting. br Benno Hi Benno, I have a 123 distributor so no trigger points. I adjusted the TPS but had trouble using a Dvm checking resistance and used the continuity to the point that there was no continuity between contacts 17 and 12 fiddling back and forth because of the contact on the posts on the arm of the tps Hi, I‘m refering to the trigger points for the ecu not for the ignition which can be found as well in the distributor. here you can find a description how to check and adjust these trigger points -> http://www.914world.com/bbs2/index.php?showtopic=271523 br Benno |
solex |
Sep 1 2020, 04:37 PM
This evening I did several things in attempt to further debug my problem:
1) Adjusted the TPS again using continuity on my DVM, based on the German site translation of https://jetronic.org/index.php/de/autos/d-j...Leerlaufkontakt (NO RESOLUTION) (2) Adjusted fuel pressure to 30 PSI (NO RESOLUTION) (2.1) Adjusted fuel pressure back to 28 PSI (3) Advanced the timing beyond 10 degrees static timing. The problem was minimized but the stumble was still present, but with added problem of a high idle ~1300 RPM (3.1) set timing back to +10 degrees at idle (4) Pulled the plug wires one at a time to see if there was an effect, and there was. The wires when grounded generated a nice spark. I had previously tightened the connectors, the were loose even though the wires are new The engine is just not idling smoothly and I went back to the advice of this forum that there must be a vacuum leak - even though I had replaced all vacuum lines earlier this year. (5) Checked all vacuum lines again and did not notice any problems. (6) Sprayed brake cleaner near at throttle body (TB) gasket. I noticed a change and at one point got the engine to stall. I tighten down the TB but the idle was the same. I also remember reading here that the plenum can be leaky. I sprayed brake cleaner under the TB mount on the plenum and think I found a leak between the plenum body and the TB, the engine stalled after a liberal amount of brake clean a few times. Any thoughts/confirmation before I remove the plenum this weekend? |
rjames |
Sep 2 2020, 01:54 AM
This evening I did several things in attempt to further debug my problem: 1) Adjusted the TPS again using continuity on my DVM, based on the German site translation of https://jetronic.org/index.php/de/autos/d-j...Leerlaufkontakt (NO RESOLUTION) (2) Adjusted fuel pressure to 30 PSI (NO RESOLUTION) (2.1) Adjusted fuel pressure back to 28 PSI (3) Advanced the timing beyond 10 degrees static timing. The problem was minimized but the stumble was still present, but with added problem of a high idle ~1300 RPM (3.1) set timing back to +10 degrees at idle (4) Pulled the plug wires one at a time to see if there was an effect, and there was. The wires when grounded generated a nice spark. I had previously tightened the connectors, the were loose even though the wires are new The engine is just not idling smoothly and I went back to the advice of this forum that there must be a vacuum leak - even though I had replaced all vacuum lines earlier this year. (5) Checked all vacuum lines again and did not notice any problems. (6) Sprayed brake cleaner near at throttle body (TB) gasket. I noticed a change and at one point got the engine to stall. I tighten down the TB but the idle was the same. I also remember reading here that the plenum can be leaky. I sprayed brake cleaner under the TB mount on the plenum and think I found a leak between the plenum body and the TB, the engine stalled after a liberal amount of brake clean a few times. Any thoughts/confirmation before I remove the plenum this weekend? Order new intake runner hoses if you’re going to remove the plenum. Your old ones are likely shot if they haven’t been replaced in a while. Plus trying to remove them without destroying them isn’t worth the hassle. |
DRPHIL914 |
Sep 3 2020, 06:47 AM
Thank you everyone. I just removed the TPS, which I replaced a few years back (>5 I think). I will check continuity, clean up with an eraser and then reinstall, adjust and will report back. I started to clean up the contacts with the eraser... i agree with all the input above andhaving been dealing with my d-jet for the past 10+ years, i'd say you are on the right track, seeing that idle change at these location sshows you have leaks that have to be addressed. with that said i would say that the TPS board you cleaned up still has an issue so glad you ordered a new one. Sometimes just cleaning it will do the job, but that looks like it was more than just oxidation but wear as well. I just had this happen again on mine. last time i did the TPS board was probably 5 years ago, and the car was doing exactly what you have happening with the bucking. Pulled my TPS with eraser and like a magic eraser, its back to normal. beatnavy and the others have said, those vac leaks will keep you from dialing this in, so just get all new seals- plenum, throttle body, intake runners etc. once you get all that done you should be able to dial in that 123ignition distributor and set your timing and idle, and enjoy the car. Mine is now runnning like a new car, probably better than new with the 123 distributor. |
solex |
Sep 5 2020, 03:57 PM
I removed the plenum and located a crack on the top side and possibly the beginning of r one the other side. I cannot see any light through these cracks but suspect when the engine gets hot they open up.
Also the TB mount does not look even, I will also remove the power coat and sand the surface flat. I started to clean them up and will weld them tomorrow and put it back together |
Lo-Fi Version | Time is now: 15th May 2024 - 05:18 PM |
