> Subaru Questions.
broomhandle
post Aug 24 2020, 02:26 PM
Hello All,
I have had a project 914 since 2009. I have a hard full of 1.7's and 2.0's, I feel I am tired of these.. plus.. the 901 I feel is the downside... from my past ownership of a 914. I have decided to go subaru. On this forum. I see so many, some go 2.0, some go 2.5? Turbo?
I am unsure of what combo to look for. It sounds like Turbo motors, need turbo 5spds. which are very hard to find. So is naturally aspirated jus fine? I would think so.
I have gotten prices of a non turbo 2.5 from 2005sih at 1500.00... ugh.
Do there majority of the sub motors mount to the transaxles? Or anybody in California want to sell a motor/trans? (IMG:style_emoticons/default/smile.gif)
I would love a turbo, but I think I am ok with a non turbo...
any help? Thoughts?
Chris914n6
post Aug 26 2020, 12:49 PM
Jackstands are my life.
You might want the 3.5L. Problem is it's newer and will need an aftermarket ECU, and I've only heard of 1 build and it's stalled. The ez30 will be alot easier.
Kent should be at the WCR20 and is open to letting just about anyone drive his car (IMG:style_emoticons/default/smile.gif) if you can wait til Nov 5. Also likely a 2.5T.
How quick do you want to be? 200hp is 60 under 6, 300hp is under 5 but you will need fatter tires.
broomhandle   Subaru Questions.   Aug 24 2020, 02:26 PM
rhodyguy   If a NA 2.5 will push a legacy wagon, it will push...   Aug 24 2020, 02:47 PM
pploco   Hello All, I have had a project 914 since 2009. ...   Aug 24 2020, 02:51 PM
lierofox   I went with an EJ20K (2.0L Turbo from a 1998 JDM S...   Aug 24 2020, 03:10 PM
mjrrti   Hello All, I have had a project 914 since 2009. ...   Aug 24 2020, 04:46 PM
Robarabian   I have a Broomhandle too in addition to an EJ 20 p...   Aug 24 2020, 07:33 PM
broomhandle   I have heard the 2.2 is a bullet proof engine. I t...   Aug 24 2020, 07:53 PM
JRust   Go with an ez30 especially if you are doing normal...   Aug 24 2020, 09:57 PM
808 WRX   It pretty much comes down to: how much horsepower ...   Aug 25 2020, 01:02 AM
broomhandle   Does anybody know what the 3.0L? what years? looks...   Aug 25 2020, 11:27 AM
mgp4591   Does anybody know what the 3.0L? what years? look...   Aug 25 2020, 12:35 PM
Chris914n6   Trans strength isn't a factor. We are 1000 lbs...   Aug 25 2020, 04:18 PM
broomhandle   Trans strength isn't a factor. We are 1000 lb...   Aug 25 2020, 05:44 PM
partwerks   Trans strength isn't a factor. We are 1000 lb...   Oct 18 2022, 08:23 PM
914forme   Maybe if you want grunt you should dare I say, loo...   Aug 25 2020, 07:28 PM
broomhandle   Maybe if you want grunt you should dare I say, lo...   Aug 26 2020, 09:35 AM
914forme   [quote name='914forme' post='2845924' date='Aug 2...   Aug 26 2020, 10:48 AM
rhodyguy   My experience with the 2.5 Legacy was short lived....   Aug 26 2020, 09:44 AM
VaccaRabite   Use the NA 6 for the low end power. Turbos need R...   Aug 26 2020, 10:23 AM
Chris914n6   You might want the 3.5L. Problem is it's newer...   Aug 26 2020, 12:49 PM
broomhandle   thanks guys, I have reached out to 76-914. as fo...   Aug 28 2020, 10:12 AM
pploco   The USDM STI 2.5 has the best of both worlds - low...   Sep 1 2020, 01:00 PM
Literati914   The USDM STI 2.5 has the best of both worlds - lo...   Sep 1 2020, 03:42 PM
lierofox   The USDM STI 2.5 has the best of both worlds - l...   Sep 2 2020, 04:23 PM
pploco   AVCS makes a big difference in lower RPM torque. T...   Sep 8 2020, 10:55 AM
partwerks   AVCS makes a big difference in lower RPM torque. ...   Aug 21 2022, 05:22 PM
partwerks   AVCS makes a big difference in lower RPM torque. ...   Aug 21 2022, 06:49 PM
VaccaRabite   @broomhandle What did you end up doing, if anyth...   Aug 22 2022, 08:08 PM
AZBanks   The EJ251 in my son's 2003 Baja developed rod ...   Oct 18 2022, 10:06 PM
- Lo-Fi Version Time is now: 9th April 2026 - 03:42 PM
