> 914-6 throttle cable - no bell crank or other bits
914forme
post Aug 25 2020, 12:35 PM
My six project I am back to getting parts to make it a runner. I read an post here I think about a cable from Patrick Motorsports that allows you to not run the bell crank and linkage. The engine in me would prefer to get ride of the rubgoldbergesk contraption that makes up the 914-6 throttle linkage.
Yes I have the factory version, and the Rich Johnson version, what can I say I like options.
I think it is this one has anyone had success with this cable?
Mark Henry
post Aug 25 2020, 03:17 PM
that's what I do!
I made mine using the stock /4 throttle cable.
-the crank from a 911, I heated it cherry so the brass melted and turned it to its new orientation.
-I used a 911 throttle pull rod, I had to cut some out of the rod length and welded it back up.
- I used a long bolt (cut off and hole drilled for cotter pin) for the crank pin, a bit of bicycle handle, some 1/16" steel, some welding drilled some holes so ot mointed on the side cover and made the tranny mount for the cable. Turned out good but was a bit overkill.
-Made the curve channel for routing the speedo clutch and throttle cable out of an old tent pole, some clamps and and I welded on some tabs, see pic below.
(IMG:http://www.914world.com/bbs2/uploads/post-26-1497650959_thumb.jpg)
Mark Henry
post Aug 26 2020, 05:06 PM
that's what I do!
QUOTE(Mark Henry @ Aug 25 2020, 05:17 PM) *
I found a couple good pic's of how I did my trans crank.
(IMG:http://www.914world.com/bbs2/uploads/post-26-1493699202.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-26-1493699098.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-26-1493699311.jpg)
914forme   914-6 throttle cable - no bell crank or other bits   Aug 25 2020, 12:35 PM
Steve   My six project I am back to getting parts to make...   Aug 25 2020, 01:12 PM
gms   The engineer in me would prefer to get ride of th...   Aug 25 2020, 01:51 PM
porschetub   The engineer in me would prefer to get ride of t...   Aug 25 2020, 06:13 PM
Mark Henry   I made mine using the stock /4 throttle cable. -t...   Aug 25 2020, 03:17 PM
Mark Henry   I made mine using the stock /4 throttle cable. -...   Aug 26 2020, 05:06 PM
Cairo94507   Hey Mark- That looks really nice. :beer2:   Aug 25 2020, 06:34 PM
nditiz1   I purchased the PMS one. It should suit my needs ...   Aug 25 2020, 06:43 PM
914forme   Thanks, Sorry to hear about your falling out with...   Aug 25 2020, 07:14 PM
porschetub   Thanks, Sorry to hear about your falling out wit...   Aug 25 2020, 11:18 PM
nditiz1   Thanks, Sorry to hear about your falling out wi...   Aug 26 2020, 05:34 AM
porschetub   [quote name='porschetub' post='2845977' date='Aug...   Aug 26 2020, 05:27 PM
Mark Henry   Pretty much what Mark H did but drilled the tra...   Aug 26 2020, 06:33 PM
roblav1   I used the /4 cable ran up to the top of the engin...   Aug 26 2020, 10:41 AM
914Toy   I installed a "marine" steering cable (?...   Aug 26 2020, 11:07 AM
Krieger   Here's how I did mine. Patrick Motorsport 914...   Aug 26 2020, 06:58 PM
Krieger   Oops   Aug 26 2020, 08:41 PM
ClayPerrine   Here is how I did mine. The 964 throttle linkag...   Aug 27 2020, 06:39 AM
- Lo-Fi Version Time is now: 3rd September 2025 - 06:37 PM
