nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Solved- i have a serpentine pulley setup. Anyone want to trade?
Has anyone used a clewitt crankfire trigger wheel and the oem style engine mount. I just put mine up to it and it will hit. If I put washer spacers behind it it should clear but this will push the engine back which will push the shift linkage back and will make the engine be further back in the bay which may mean not a good seal. Anyone dealt with this? (IMG:style_emoticons/default/confused24.gif) |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,614 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Has anyone used a clewitt crankfire trigger wheel and the oem style engine mount. I just put mine up to it and it will hit. If I put washer spacers behind it it should clear but this will push the engine back which will push the shift linkage back and will make the engine be further back in the bay which may mean not a good seal. Anyone dealt with this? (IMG:style_emoticons/default/confused24.gif) I am sure there are many that do.. I have no experience as I use a 123 dizzy. |
Lo-Fi Version | Time is now: 31st July 2025 - 02:00 AM |
