nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Solved- i have a serpentine pulley setup. Anyone want to trade?
Has anyone used a clewitt crankfire trigger wheel and the oem style engine mount. I just put mine up to it and it will hit. If I put washer spacers behind it it should clear but this will push the engine back which will push the shift linkage back and will make the engine be further back in the bay which may mean not a good seal. Anyone dealt with this? (IMG:style_emoticons/default/confused24.gif) |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Souls be enough of a margin it will work, not like you need inches just fractions of an inch. I would go for it. Draw it out in cad, and have it laser cut in the thickness you need
Lo-Fi Version | Time is now: 31st July 2025 - 01:52 AM |
