| brcacti |
Aug 28 2020, 05:45 PM
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Hello, can I hear from someone who has don the odometer fix? Did you deform the gear as instructed in the pelican parts instructions?
| brcacti |
Aug 29 2020, 08:27 AM
From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear.
| bdstone914 |
Aug 29 2020, 09:04 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,430 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@brcacti
' date='Aug 29 2020, 07:27 AM' post='2846887'] From people who did this was there enough room to get pliers or vise grips on the part you crimp. Someone mentioned the part you crimp does not stick out far from the gear. [/quote] I found no room to get any room to get pliers in there. I had another speedo and used the shaft from it to deform it. I was able to push out the original shaft with the other shaft to keep all the gears in place. |
brcacti odometer fix who has done this? Aug 28 2020, 05:45 PM
Nojoah
Hello, can I hear from someone who has don the od... Aug 29 2020, 07:54 AM
mepstein Drop of superglue helps. Aug 29 2020, 08:27 AM
porschetub
@[url=http://www.914world.com/bbs2/index.php?show... Aug 29 2020, 07:15 PM
brcacti
[quote name='bdstone914' date='Aug 30... Aug 29 2020, 08:42 PM
PanelBilly I did it years ago, It worked for awhile and then ... Aug 29 2020, 08:33 AM
brcacti Hello ALL, I have the odometer back together, is t... Aug 29 2020, 04:15 PM
76-914 Took me 3 times before all of the digits aligned e... Aug 29 2020, 06:11 PM
brcacti
Took me 3 times before all of the digits aligned ... Aug 29 2020, 08:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 05:40 AM |
