| fixer34 |
Aug 23 2020, 12:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,405 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Bought one of the Rothsport oil valves because I was tired of cleaning up oil after taking the car out. Installing it was my weekend project (what did you do to your 914...?) Had the pull the heat exchanger, and the hose connection at the oil cooler came off surprisingly easy. The connection at the U bracket is another story. It hasn't been loosened in at least 30 years and having no luck breaking it loose. Any suggestions?
And before you ask 'how did I change the oil?'; the car has been driven less than 10k miles in the last 30 years, and 'oil changes' were done almost on a continuous basis by refilling since the leakback was so bad anytime I drove it. New lower valve covers & gaskets helped, but it still drained about half the tank when it sat for several months. |
| gms |
Aug 31 2020, 08:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
fixer34 Oil line on a six Aug 23 2020, 12:27 PM
fixer34 I'm thinking I may have to invest in wrenches,... Aug 23 2020, 01:57 PM
Mark Henry I'd get the correct wrenches, someday you... Aug 23 2020, 02:05 PM
fixer34
I'd get the correct wrenches, someday you... Aug 23 2020, 02:11 PM
porschetub When I put my oil lines together I purchased a che... Aug 23 2020, 02:41 PM
fixer34
When I put my oil lines together I purchased a ch... Aug 23 2020, 03:03 PM
porschetub
When I put my oil lines together I purchased a c... Aug 23 2020, 05:46 PM
GeorgeRud They’re 32 and 36mm, and it’s best to get the ... Aug 23 2020, 07:15 PM
fixer34
They’re 32 and 36mm, and it’s best to get the... Aug 23 2020, 07:46 PM
gereed75 Harbor Frieght has a set of large metric open end ... Aug 23 2020, 07:28 PM
fixer34
Harbor Frieght has a set of large metric open end... Aug 23 2020, 07:44 PM
gms you can borrow mine if you want, I am located in B... Aug 23 2020, 08:10 PM
fixer34
you can borrow mine if you want, I am located in ... Aug 23 2020, 08:25 PM
fixer34
you can borrow mine if you want, I am located in ... Aug 25 2020, 07:46 PM
9146GUY Biggest issue I see is that one fitting is steel a... Aug 24 2020, 07:42 AM
fixer34
Biggest issue I see is that one fitting is steel ... Aug 24 2020, 08:25 AM
rgalla9146 In your photo both sides are steel, the aluminum i... Aug 24 2020, 09:36 AM
fixer34
In your photo both sides are steel, the aluminum ... Aug 24 2020, 09:41 AM
slivel
In your photo both sides are steel, the aluminum ... Aug 24 2020, 10:18 AM
Mark Henry You can buy new or contact pelican parts member Bo... Aug 25 2020, 08:01 PM
johnlush The early lines like yours can be rebuilt as long ... Aug 25 2020, 08:50 PM
fixer34
The early lines like yours can be rebuilt as long... Aug 26 2020, 08:46 AM
Mark Henry
Too me the cooler end is cut a little too clo... Aug 26 2020, 12:48 PM
fixer34
Too me the cooler end is cut a little too cl... Aug 26 2020, 03:05 PM
rgalla9146 Don't discard your original plumbing.
As... Aug 26 2020, 04:45 AM
mlindner Does the Rothsport valve need to be put into a cut... Aug 26 2020, 08:07 AM
Krieger
Does the Rothsport valve need to be put into a cu... Aug 26 2020, 08:45 AM
fixer34
Does the Rothsport valve need to be put into a c... Aug 26 2020, 08:50 AM
fixer34
[quote name='Krieger' post='2846042' date='Aug 26... Aug 26 2020, 08:58 AM
johnlush I'd be glad to help but honestly if you've... Aug 26 2020, 10:06 AM
fixer34
I'd be glad to help but honestly if you'v... Aug 26 2020, 10:39 AM
porschetub You have to use a special hose with the reusable f... Aug 26 2020, 03:20 PM
Cairo94507 @rgalla9146 Thanks for the tip about the Stoddar... Aug 26 2020, 05:40 PM
porschetub
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 26 2020, 09:10 PM
[quote name='Cairo94507' post='2846181' date='Aug... Aug 27 2020, 05:59 AM
porschetub
[quote name='Cairo94507' post='2846181' date='Au... Aug 28 2020, 05:41 PM
rudedude I like the wrench for the tank connection. Sure b... Aug 27 2020, 07:18 PM
gms @fixer34 looks like got it apart? Aug 27 2020, 08:10 PM
fixer34
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 28 2020, 04:21 PM
914forme Where do you get the 30mm to 30mm with drain plug? Aug 28 2020, 07:36 PM
gereed75 I believe the 30 x 30 is in there. I just took min... Aug 28 2020, 07:43 PM
914forme Thanks @greed75, I found the plain ones, and yes ... Aug 29 2020, 06:18 AM
fixer34 I changed the description text as I'm making p... Aug 30 2020, 07:00 PM
Krieger
I changed the description text as I'm making ... Aug 30 2020, 08:32 PM
gereed75 You have the original OEM lines. There was no ... Aug 30 2020, 10:43 PM
johnlush FWIW, none of the fittings I have are left hand th... Aug 30 2020, 08:37 PM
porschetub
FWIW, none of the fittings I have are left hand t... Sep 4 2020, 02:47 PM
fixer34
[quote name='johnlush' post='2847308' date='Aug 3... Sep 4 2020, 04:06 PM
rgalla9146 All threads are conventional, no reverse except th... Aug 31 2020, 06:51 AM
fixer34
I took a little different approach HERE
Sadly, n... Aug 31 2020, 11:26 AM
johnlush Search for "Alltrade Strap Wrench". You ... Aug 31 2020, 11:52 AM
fixer34 So, "with a little (LOT) help from my friends... Sep 3 2020, 05:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:23 AM |
