> Oil line on a six, hose and valve installed!
fixer34
post Aug 23 2020, 12:27 PM
Bought one of the Rothsport oil valves because I was tired of cleaning up oil after taking the car out. Installing it was my weekend project (what did you do to your 914...?) Had the pull the heat exchanger, and the hose connection at the oil cooler came off surprisingly easy. The connection at the U bracket is another story. It hasn't been loosened in at least 30 years and having no luck breaking it loose. Any suggestions?
And before you ask 'how did I change the oil?'; the car has been driven less than 10k miles in the last 30 years, and 'oil changes' were done almost on a continuous basis by refilling since the leakback was so bad anytime I drove it. New lower valve covers & gaskets helped, but it still drained about half the tank when it sat for several months. Attached Image Attached Image
fixer34
post Aug 30 2020, 07:00 PM
I changed the description text as I'm making progress.
Not quite sure where the 30x30 drain plug sub-thread came in, but that's cool. Kind of wondering where it would go anyway, I don't see any place on my line that has that type of connection.
As for progress, got the new line from BelMatic Friday, came in 2 days. Test fitted the check value and all is good. Going to buy a strap wrench tomorrow to see if I can loosen the aluminum housings without doing permanent damage. One of the pictures shows how it threads together (thank you...), but it was also mentioned that the threads are left-hand?? Can someone confirm so I don't go horsing on this in the wrong direction?
Pete
johnlush
post Aug 30 2020, 08:37 PM
What's all this then?
FWIW, none of the fittings I have are left hand threaded.
QUOTE(fixer34 @ Aug 30 2020, 07:00 PM) *
Pete
porschetub
post Sep 4 2020, 02:47 PM
QUOTE(johnlush @ Aug 31 2020, 02:37 PM) *
Pete
John I only mentioned the outer alloy piece was LH thread,these reusable fitting are different to the ones we used on the ships as our outer collars were steel and had a hex on them.....much easier to take apart and assemble.
fixer34   Oil line on a six   Aug 23 2020, 12:27 PM
fixer34   I'm thinking I may have to invest in wrenches,...   Aug 23 2020, 01:57 PM
Mark Henry   I'd get the correct wrenches, someday you...   Aug 23 2020, 02:05 PM
fixer34   I'd get the correct wrenches, someday you...   Aug 23 2020, 02:11 PM
porschetub   When I put my oil lines together I purchased a che...   Aug 23 2020, 02:41 PM
fixer34   When I put my oil lines together I purchased a ch...   Aug 23 2020, 03:03 PM
porschetub   When I put my oil lines together I purchased a c...   Aug 23 2020, 05:46 PM
GeorgeRud   They’re 32 and 36mm, and it’s best to get the ...   Aug 23 2020, 07:15 PM
fixer34   They’re 32 and 36mm, and it’s best to get the...   Aug 23 2020, 07:46 PM
gereed75   Harbor Frieght has a set of large metric open end ...   Aug 23 2020, 07:28 PM
fixer34   Harbor Frieght has a set of large metric open end...   Aug 23 2020, 07:44 PM
gms   you can borrow mine if you want, I am located in B...   Aug 23 2020, 08:10 PM
fixer34   you can borrow mine if you want, I am located in ...   Aug 23 2020, 08:25 PM
fixer34   you can borrow mine if you want, I am located in ...   Aug 25 2020, 07:46 PM
9146GUY   Biggest issue I see is that one fitting is steel a...   Aug 24 2020, 07:42 AM
fixer34   Biggest issue I see is that one fitting is steel ...   Aug 24 2020, 08:25 AM
rgalla9146   In your photo both sides are steel, the aluminum i...   Aug 24 2020, 09:36 AM
fixer34   In your photo both sides are steel, the aluminum ...   Aug 24 2020, 09:41 AM
slivel   In your photo both sides are steel, the aluminum ...   Aug 24 2020, 10:18 AM
Mark Henry   You can buy new or contact pelican parts member Bo...   Aug 25 2020, 08:01 PM
johnlush   The early lines like yours can be rebuilt as long ...   Aug 25 2020, 08:50 PM
fixer34   The early lines like yours can be rebuilt as long...   Aug 26 2020, 08:46 AM
Mark Henry   Too me the cooler end is cut a little too clo...   Aug 26 2020, 12:48 PM
fixer34   Too me the cooler end is cut a little too cl...   Aug 26 2020, 03:05 PM
rgalla9146   Don't discard your original plumbing. As...   Aug 26 2020, 04:45 AM
mlindner   Does the Rothsport valve need to be put into a cut...   Aug 26 2020, 08:07 AM
Krieger   Does the Rothsport valve need to be put into a cu...   Aug 26 2020, 08:45 AM
fixer34   Does the Rothsport valve need to be put into a c...   Aug 26 2020, 08:50 AM
fixer34   [quote name='Krieger' post='2846042' date='Aug 26...   Aug 26 2020, 08:58 AM
johnlush   I'd be glad to help but honestly if you've...   Aug 26 2020, 10:06 AM
fixer34   I'd be glad to help but honestly if you'v...   Aug 26 2020, 10:39 AM
porschetub   You have to use a special hose with the reusable f...   Aug 26 2020, 03:20 PM
Cairo94507   @rgalla9146 Thanks for the tip about the Stoddar...   Aug 26 2020, 05:40 PM
porschetub   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 26 2020, 09:10 PM
mepstein   [quote name='Cairo94507' post='2846181' date='Aug...   Aug 27 2020, 05:59 AM
porschetub   [quote name='Cairo94507' post='2846181' date='Au...   Aug 28 2020, 05:41 PM
rudedude   I like the wrench for the tank connection. Sure b...   Aug 27 2020, 07:18 PM
gms   @fixer34 looks like got it apart?   Aug 27 2020, 08:10 PM
fixer34   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 28 2020, 04:21 PM
914forme   Where do you get the 30mm to 30mm with drain plug?   Aug 28 2020, 07:36 PM
gereed75   I believe the 30 x 30 is in there. I just took min...   Aug 28 2020, 07:43 PM
914forme   Thanks @greed75, I found the plain ones, and yes ...   Aug 29 2020, 06:18 AM
fixer34   I changed the description text as I'm making p...   Aug 30 2020, 07:00 PM
Krieger   I changed the description text as I'm making ...   Aug 30 2020, 08:32 PM
gereed75   You have the original OEM lines. There was no ...   Aug 30 2020, 10:43 PM
johnlush   FWIW, none of the fittings I have are left hand th...   Aug 30 2020, 08:37 PM
porschetub   FWIW, none of the fittings I have are left hand t...   Sep 4 2020, 02:47 PM
fixer34   [quote name='johnlush' post='2847308' date='Aug 3...   Sep 4 2020, 04:06 PM
rgalla9146   All threads are conventional, no reverse except th...   Aug 31 2020, 06:51 AM
gms   I took a little different approach HERE   Aug 31 2020, 08:12 AM
fixer34   I took a little different approach HERE Sadly, n...   Aug 31 2020, 11:26 AM
johnlush   Search for "Alltrade Strap Wrench". You ...   Aug 31 2020, 11:52 AM
fixer34   So, "with a little (LOT) help from my friends...   Sep 3 2020, 05:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:27 AM
