| R Dub |
Sep 4 2020, 08:16 PM
Member ![]() ![]() Group: Members Posts: 126 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
The wife and I were driving home today after lunch and was making a left turn when heard a loud pop and instantly no drive. Had power but it would not move. After jacking the car up, noticed the axle on the driver side came off, the bolts backed out. They didn't snap or strip, just backed out. I Uber home to get my truck and tools and was able tighten the bolts back up. However after pulling away, went to shift to 2nd and it grinded hard, shifted into 3rd OK, when to 4th and nothing, then tried 5th and nothing. So seems all I have is 1st, 3rd and Reverse.
Already PM Dr. Evil about a rebuild and possible and cost. Just a crap way to finish a good day. Just glad to get it home On a positive note a guy stopped to see if we were OK and said he used to have a 914 that he loved (up until he crashed it) |
| ClayPerrine |
Sep 5 2020, 09:29 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Replace the schnorr washers under the head of the bolts. Then reassemble the CV joint, using a new gasket and a torque wrench to install the bolts. The torque spec is 31 ft/lbs. Make sure the bolts are clean when going into the flange. No grease on the threads.
If you use new schnorr washers and gaskets every time you disassemble the CV joints, and torque them correctly, they will not back out like you experienced. Safety wire is a good idea if you want to go to that trouble, but it is not necessary to keep the bolts from backing out. |
| R Dub |
Sep 5 2020, 02:22 PM
Replace the schnorr washers under the head of the bolts. Then reassemble the CV joint, using a new gasket and a torque wrench to install the bolts. The torque spec is 31 ft/lbs. Make sure the bolts are clean when going into the flange. No grease on the threads. If you use new schnorr washers and gaskets every time you disassemble the CV joints, and torque them correctly, they will not back out like you experienced. Safety wire is a good idea if you want to go to that trouble, but it is not necessary to keep the bolts from backing out. Thanks for the tip. Will get new ones on order |
R Dub Possible trans rebuild Sep 4 2020, 08:16 PM
Dr Evil See my PM to you.
I’m betting your messed up sh... Sep 4 2020, 08:57 PM
R Dub
See my PM to you.
I’m betting your messed up s... Sep 4 2020, 09:04 PM
mlindner And drill and safety wire the allen bolts so it do... Sep 5 2020, 05:13 AM
R Dub Worked on the car a bit today and hoping the exper... Sep 5 2020, 02:33 PM
Bartlett 914 that bushing is shot. remove the cone screw comple... Sep 5 2020, 02:36 PM
Dr Evil Check forward to the firewall and the u joint. Lik... Sep 5 2020, 02:54 PM
R Dub
Check forward to the firewall and the u joint. Li... Sep 5 2020, 03:02 PM
rbzymek
[quote name='Dr Evil' post='2848770' date='Sep 5 ... Sep 5 2020, 03:23 PM
Dr Evil
[quote name='Dr Evil' post='2848770' date='Sep 5... Sep 5 2020, 05:03 PM
EdwardBlume Fix the whole set of bushings and you’ll be good... Sep 5 2020, 08:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:06 PM |
