| Robson51 |
Sep 5 2020, 12:00 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money? TIA |
| rjames |
Sep 5 2020, 03:17 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,495 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I just spent the last 2 summers get my DJet back in running order and may be able to help.
That said, give as many details as you can and maybe with everyone's help here it can be a remote fix. (IMG:style_emoticons/default/smile.gif) |
| Robson51 |
Sep 5 2020, 04:28 PM
I just spent the last 2 summers get my DJet back in running order and may be able to help. That said, give as many details as you can and maybe with everyone's help here it can be a remote fix. (IMG:style_emoticons/default/smile.gif) OK-here's the list. Injectors rebuilt by Witchhunter, but one always left a plug wet, so it has recently been changed to a NOS one AAV tests good, as does the MPC. New TPS set with an ohm meter. New gaskets and sleeves on the intake manifold, new vacuum hoses. Fuel pump tested at 28 pounds. Compression over 125 on all cylinders. Valves set. New Pertronix, cap, rotor and wires. Timing set properly at full advance. Trigger points looked really good and were checked that they were contacting. New connectors on injector wiring harness. ECU is set 11 clicks from full stop left. Car is hard to start, and seems to flood. Just put a clamp on the cold start injector and it seems to start easier. Need to get it out on the road to clear it out. My latest thought is the cold start injector is on all the time or bad or leaking. Taking it out of the system seemed to help but the car is so loaded up with fuel it will take a while to get it to run clean. Any other ideas? I'm really to the point where I think it needs fresh eyes on it. Thanks- |
Robson51 Any D Jet experts in Seattle? Sep 5 2020, 12:00 PM
sixnotfour @914werke millcreek area Sep 5 2020, 12:02 PM
Robson51
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 5 2020, 12:36 PM
Jett Redmond European... Monty has the right equipment ... Sep 5 2020, 02:12 PM
Bleyseng What's wrong with it? I am on Beacon Hill. Ric... Sep 5 2020, 03:03 PM
Bleyseng First- Is the Cylinder Temp sensor good? Test it p... Sep 5 2020, 05:26 PM
Robson51
First- Is the Cylinder Temp sensor good? Test it ... Sep 5 2020, 05:57 PM
914werke Sorry, been convalescing. But try & help anywa... Sep 5 2020, 05:56 PM
Bleyseng MPS number is 043? ECU number is ending in 044?
S... Sep 5 2020, 06:46 PM
Robson51
... Sep 5 2020, 07:32 PM
Robson51
... Sep 7 2020, 12:18 PM
Bleyseng "ECU is 11 clicks from full stop left"
D... Sep 5 2020, 07:12 PM
Robson51
... Sep 6 2020, 09:07 AM
Bleyseng
"ECU is 11 clicks from full stop left... Sep 6 2020, 04:53 PM
Robson51
[quote name='Robson51' post='2848954' date='Sep 6... Sep 8 2020, 02:31 PM
mightyohm Cold start should not be operating this time of ye... Sep 6 2020, 06:26 PM
Robson51
Cold start should not be operating this time of y... Sep 7 2020, 01:27 PM
rjames Did the car ever run well with the parts it has in... Sep 7 2020, 11:04 AM
Robson51
Did the car ever run well with the parts it has i... Sep 7 2020, 01:26 PM
rjames
Very likely it needs to be tuned for your car. T... Sep 7 2020, 02:48 PM
Rand Bypass the CSV, you don't need it and it's... Sep 7 2020, 02:50 PM
Robson51 for an update-car is running and getting better al... Sep 14 2020, 11:42 AM
Bleyseng I think I have a good used one if you want for rea... Sep 14 2020, 02:10 PM
Robson51
I think I have a good used one if you want for re... Sep 15 2020, 03:50 PM
914werke Rechecked the MPS with a better vacuum gauge. It... Sep 14 2020, 03:22 PM
Rand
[quote name='Robson51' post='2851240' date='Sep 1... Sep 14 2020, 03:44 PM
Robson51
[quote name='Robson51' post='2851240' date='Sep ... Sep 15 2020, 03:43 PM
Rand
Actually, it died when I did that. The leakdown ... Sep 15 2020, 07:11 PM
Bleyseng
Actually, it died when I did that. The leakdown... Sep 16 2020, 08:21 AM
Rand
[quote name='Rand' post='2851653' date='Sep 15 20... Sep 16 2020, 04:04 PM
thelogo Stop me if you've heard this one ( i know you ... Sep 16 2020, 04:18 PM
Bleyseng
Stop me if you've heard this one ( i know you... Sep 16 2020, 07:03 PM
rjames @Rand Correct me if I'm wrong, but I don... Sep 16 2020, 04:35 PM
Rand
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 16 2020, 04:49 PM
Rand logoman loves to stir the carb pot. I get it, it... Sep 16 2020, 07:17 PM
Bleyseng My has run so well since 1997 I can't bring my... Sep 16 2020, 08:35 PM
Rand
My has run so well since 1997 I can't bring m... Sep 16 2020, 08:39 PM
bobforman Try George at Porbug in Edmonds. Sep 16 2020, 11:39 PM
Robson51
Thanks-that... Sep 17 2020, 03:23 PM
Bleyseng There is also Denny Akers Porsche on Capital Hill. Sep 17 2020, 09:01 AM
rjames @Robson51 Hopefully the rebuilt and recalibrated ... Sep 17 2020, 12:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th November 2026 - 02:23 PM |
