> Any D Jet experts in Seattle?
Robson51
post Sep 5 2020, 12:00 PM
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money?
TIA
rjames
post Sep 7 2020, 11:04 AM
I'm made of metal
Did the car ever run well with the parts it has installed? If yes, when did the issue started happening?
If running rich check:
MPS leaking or not set correctly for your engine (is it original to your car? Is the seal still in place?)
ECU knob in wrong spot (put it in the middle and go from there)
CHT sensor
Check injection harness grounds (they are grounded to the chassis at the back of the engine)
If you unplug the air temp sensor (on the plenum on the driver’s side next to the AAR valve) does it get better?
Ruling out your injectors since they were just serviced.
All the DJet info you could want:
https://members.rennlist.com/pbanders/DJetParts.htm#parts
Robson51
post Sep 7 2020, 01:26 PM
QUOTE(rjames @ Sep 7 2020, 10:04 AM) *
CHT sensor
Checked MPS and not leaking. It's a replacement from original as a spare was included with the car in a box of old parts.
ECU knob in the middle
CHT sensor new from 914Rubber
Harness grounds spotless.
Have not unplugged the air temp sensor.
The weird thing is that it was running and driving, not perfectly but OK. Drove it to a soccer game, wouldn't start and turned out to be a fuel pump relay. Changed out the relay, now really rich and not running well enough to drive.
Robson51   Any D Jet experts in Seattle?   Sep 5 2020, 12:00 PM
sixnotfour   @914werke millcreek area   Sep 5 2020, 12:02 PM
Robson51   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 5 2020, 12:36 PM
Jett   Redmond European... Monty has the right equipment ...   Sep 5 2020, 02:12 PM
Bleyseng   What's wrong with it? I am on Beacon Hill. Ric...   Sep 5 2020, 03:03 PM
rjames   I just spent the last 2 summers get my DJet back i...   Sep 5 2020, 03:17 PM
Robson51   I just spent the last 2 summers get my DJet back ...   Sep 5 2020, 04:28 PM
Bleyseng   First- Is the Cylinder Temp sensor good? Test it p...   Sep 5 2020, 05:26 PM
Robson51   First- Is the Cylinder Temp sensor good? Test it ...   Sep 5 2020, 05:57 PM
914werke   Sorry, been convalescing. But try & help anywa...   Sep 5 2020, 05:56 PM
Bleyseng   MPS number is 043? ECU number is ending in 044? S...   Sep 5 2020, 06:46 PM
Robson51   MPS number is 043? ECU number is ending in 044? ...   Sep 5 2020, 07:32 PM
Robson51   MPS number is 043? ECU number is ending in 044? ...   Sep 7 2020, 12:18 PM
Bleyseng   "ECU is 11 clicks from full stop left" D...   Sep 5 2020, 07:12 PM
Robson51   "ECU is 11 clicks from full stop left" ...   Sep 6 2020, 09:07 AM
Bleyseng   "ECU is 11 clicks from full stop left...   Sep 6 2020, 04:53 PM
Robson51   [quote name='Robson51' post='2848954' date='Sep 6...   Sep 8 2020, 02:31 PM
mightyohm   Cold start should not be operating this time of ye...   Sep 6 2020, 06:26 PM
Robson51   Cold start should not be operating this time of y...   Sep 7 2020, 01:27 PM
rjames   Did the car ever run well with the parts it has in...   Sep 7 2020, 11:04 AM
Robson51   Did the car ever run well with the parts it has i...   Sep 7 2020, 01:26 PM
rjames   Very likely it needs to be tuned for your car. T...   Sep 7 2020, 02:48 PM
Rand   Bypass the CSV, you don't need it and it's...   Sep 7 2020, 02:50 PM
Robson51   for an update-car is running and getting better al...   Sep 14 2020, 11:42 AM
Bleyseng   I think I have a good used one if you want for rea...   Sep 14 2020, 02:10 PM
Robson51   I think I have a good used one if you want for re...   Sep 15 2020, 03:50 PM
914werke   Rechecked the MPS with a better vacuum gauge. It...   Sep 14 2020, 03:22 PM
Rand   [quote name='Robson51' post='2851240' date='Sep 1...   Sep 14 2020, 03:44 PM
Robson51   [quote name='Robson51' post='2851240' date='Sep ...   Sep 15 2020, 03:43 PM
Rand   Actually, it died when I did that. The leakdown ...   Sep 15 2020, 07:11 PM
Bleyseng   Actually, it died when I did that. The leakdown...   Sep 16 2020, 08:21 AM
Rand   [quote name='Rand' post='2851653' date='Sep 15 20...   Sep 16 2020, 04:04 PM
thelogo   Stop me if you've heard this one ( i know you ...   Sep 16 2020, 04:18 PM
Bleyseng   Stop me if you've heard this one ( i know you...   Sep 16 2020, 07:03 PM
rjames   @Rand Correct me if I'm wrong, but I don...   Sep 16 2020, 04:35 PM
Rand   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 16 2020, 04:49 PM
Rand   logoman loves to stir the carb pot. I get it, it...   Sep 16 2020, 07:17 PM
Bleyseng   My has run so well since 1997 I can't bring my...   Sep 16 2020, 08:35 PM
Rand   My has run so well since 1997 I can't bring m...   Sep 16 2020, 08:39 PM
bobforman   Try George at Porbug in Edmonds.   Sep 16 2020, 11:39 PM
Robson51   Try George at Porbug in Edmonds. Thanks-that...   Sep 17 2020, 03:23 PM
Bleyseng   There is also Denny Akers Porsche on Capital Hill.   Sep 17 2020, 09:01 AM
rjames   @Robson51 Hopefully the rebuilt and recalibrated ...   Sep 17 2020, 12:04 PM
- Lo-Fi Version Time is now: 26th November 2026 - 02:23 PM
