| mburkhart |
Sep 8 2020, 08:44 AM
Member ![]() ![]() Group: Members Posts: 113 Joined: 3-July 05 From: Chester, MD Member No.: 4,364 Region Association: MidAtlantic Region |
So I was out for a cruise around the neighborhood the other day and things were going great until the brake pedal went to the floor. I was able to pump it a few times and restore pressure and crawled home in a low gear. Each time I used the brakes the pedal would go to the floor until I pumped it a few times. Scary!
Once home I looked under the car and inspected the soft lines at each caliper but they looked fine and no leaks. The brake fluid reservoir is still full. I'm not sure where the problem is. What should I be looking for? |
| billh1963 |
Sep 9 2020, 09:02 AM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
I'll throw out another possibility....
One day while while driving the 6 conversion in my avatar, I came up to a stop and much to my chagrin I discovered I had virtually no brakes. Fortunately, my emergency brakes worked quite well and I was able to stop. (BTW...when driving my older cars I ALWAYS slow down early and give the brakes a little test tap. It's a habit I developed early in life when driving another car that experienced brake failure.) Anyway, as I sat waiting over an hour for a AAA tow for some reason I hit the brake pedal. I had brakes! I drove the short distance home and as I walked around the car I could feel the heat coming off the right front wheel. The right front caliper was dragging so badly that the fluid was boiling ..causing a loss of braking. I replaced the rubber brake hoses (in case they were collapsed) and with a set of rebuilt calipers a few days later I was back in business! That may not be your problem. But, worth a check especially if you aren't seeing any fluid loss. |
| mburkhart |
Sep 9 2020, 09:39 AM
I'll throw out another possibility.... One day while while driving the 6 conversion in my avatar, I came up to a stop and much to my chagrin I discovered I had virtually no brakes. Fortunately, my emergency brakes worked quite well and I was able to stop. (BTW...when driving my older cars I ALWAYS slow down early and give the brakes a little test tap. It's a habit I developed early in life when driving another car that experienced brake failure.) Anyway, as I sat waiting over an hour for a AAA tow for some reason I hit the brake pedal. I had brakes! I drove the short distance home and as I walked around the car I could feel the heat coming off the right front wheel. The right front caliper was dragging so badly that the fluid was boiling ..causing a loss of braking. I replaced the rubber brake hoses (in case they were collapsed) and with a set of rebuilt calipers a few days later I was back in business! That may not be your problem. But, worth a check especially if you aren't seeing any fluid loss. Any idea how to check for this without going out for another scary drive? This sounds like a possibility since the brakes went out about 15 minutes into my leisurely drive. I checked the pedals for fluid yesterday and the brake pedal had pressure (and no fluid leaking)... |
| VaccaRabite |
Sep 9 2020, 09:46 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I'll throw out another possibility.... Anyway, as I sat waiting over an hour for a AAA tow for some reason I hit the brake pedal. I had brakes! I drove the short distance home and as I walked around the car I could feel the heat coming off the right front wheel. The right front caliper was dragging so badly that the fluid was boiling ..causing a loss of braking. I replaced the rubber brake hoses (in case they were collapsed) and with a set of rebuilt calipers a few days later I was back in business! Any idea how to check for this without going out for another scary drive? This sounds like a possibility since the brakes went out about 15 minutes into my leisurely drive. I checked the pedals for fluid yesterday and the brake pedal had pressure (and no fluid leaking)... That one is easy. Look at your pads and see if one pair is wearing WAY FASTER then the other. The four front pads should be similar, and the 4 rear pads should be similar. Also, if pads are stuck on the rotor, the rotor is probably also worn more too, if not scored and warped. Zach |
mburkhart No brakes! Sep 8 2020, 08:44 AM
mepstein Master cylinder
Look for fluid under the pedal as... Sep 8 2020, 08:47 AM
DRPHIL914
Master cylinder
Look for fluid under the pedal a... Sep 8 2020, 08:57 AM
mburkhart I haven't had time to lift the car up to be ab... Sep 8 2020, 09:03 AM
DRPHIL914
I haven't had time to lift the car up to be a... Sep 8 2020, 11:19 AM
mburkhart What are folks thoughts on the original 17mm vs 19... Sep 8 2020, 02:05 PM
ClayPerrine
What are folks thoughts on the original 17mm vs 1... Sep 8 2020, 05:33 PM
dcheek
What are folks thoughts on the original 17mm vs 1... Sep 9 2020, 09:00 AM
fiacra
Master cylinder
Look for fluid under the pedal a... Sep 8 2020, 10:13 AM
brant if the MC leaked on the pedals
make sure you rebui... Sep 8 2020, 09:14 AM
solex When was the last time you replaced your brake flu... Sep 8 2020, 09:32 AM
76-914 RE; the non-easy install MC version; You can get a... Sep 8 2020, 02:57 PM
mepstein Im pretty sure I have the 19mm easy install versio... Sep 8 2020, 05:47 PM
Tdskip Check me on this - the only difference between reg... Sep 9 2020, 06:50 AM
Check me on this - the only difference between re... Sep 9 2020, 07:38 AM
DRPHIL914
Check me on this - the only difference between r... Sep 9 2020, 08:32 AM
Optimusglen When I did mine I installed on a bench, just the l... Sep 9 2020, 08:41 AM
mepstein Never forget the washers. They are 100% mandatory.... Sep 9 2020, 08:55 AM
stugray
One d... Sep 13 2020, 10:29 AM
VaccaRabite The difference between the 17mm and the 19mm is on... Sep 9 2020, 09:35 AM
mepstein Did you pull the carpet and the pedal plywood and ... Sep 9 2020, 10:36 AM
mburkhart
Did you pull the carpet and the pedal plywood and... Sep 9 2020, 11:51 AM
Did you pull the carpet and the pedal plywood an... Sep 9 2020, 12:33 PM
Craigers17 I did this a few months ago. I used this advice b... Sep 9 2020, 01:47 PM
mburkhart Well it looks like the caliper is the culprit. Br... Sep 12 2020, 02:57 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 12 2020, 06:50 PM
stugray
@[url=http://www.914world.com/bbs2/index.php?show... Sep 13 2020, 10:32 AM
Mikey914 I know we are making more now and may be able to l... Sep 12 2020, 09:49 PM
porschetub As far as failure. If there are not any apparent l... Sep 13 2020, 01:56 PM
sixnotfour
Old brake fluid increases the diagnoses.. Sep 13 2020, 12:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th April 2026 - 05:47 AM |
