| mburkhart |
Sep 8 2020, 08:44 AM
Member ![]() ![]() Group: Members Posts: 113 Joined: 3-July 05 From: Chester, MD Member No.: 4,364 Region Association: MidAtlantic Region |
So I was out for a cruise around the neighborhood the other day and things were going great until the brake pedal went to the floor. I was able to pump it a few times and restore pressure and crawled home in a low gear. Each time I used the brakes the pedal would go to the floor until I pumped it a few times. Scary!
Once home I looked under the car and inspected the soft lines at each caliper but they looked fine and no leaks. The brake fluid reservoir is still full. I'm not sure where the problem is. What should I be looking for? |
| mepstein |
Sep 9 2020, 10:36 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,625 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Did you pull the carpet and the pedal plywood and stick your hand around the pedal assembly. Mine wasn't much but it was wet. Nothing under the car or on the ground.
mburkhart No brakes! Sep 8 2020, 08:44 AM
mepstein Master cylinder
Look for fluid under the pedal as... Sep 8 2020, 08:47 AM
DRPHIL914
Master cylinder
Look for fluid under the pedal a... Sep 8 2020, 08:57 AM
mburkhart I haven't had time to lift the car up to be ab... Sep 8 2020, 09:03 AM
DRPHIL914
I haven't had time to lift the car up to be a... Sep 8 2020, 11:19 AM
mburkhart What are folks thoughts on the original 17mm vs 19... Sep 8 2020, 02:05 PM
ClayPerrine
What are folks thoughts on the original 17mm vs 1... Sep 8 2020, 05:33 PM
dcheek
What are folks thoughts on the original 17mm vs 1... Sep 9 2020, 09:00 AM
fiacra
Master cylinder
Look for fluid under the pedal a... Sep 8 2020, 10:13 AM
brant if the MC leaked on the pedals
make sure you rebui... Sep 8 2020, 09:14 AM
solex When was the last time you replaced your brake flu... Sep 8 2020, 09:32 AM
76-914 RE; the non-easy install MC version; You can get a... Sep 8 2020, 02:57 PM
mepstein Im pretty sure I have the 19mm easy install versio... Sep 8 2020, 05:47 PM
Tdskip Check me on this - the only difference between reg... Sep 9 2020, 06:50 AM
Check me on this - the only difference between re... Sep 9 2020, 07:38 AM
DRPHIL914
Check me on this - the only difference between r... Sep 9 2020, 08:32 AM
Optimusglen When I did mine I installed on a bench, just the l... Sep 9 2020, 08:41 AM
mepstein Never forget the washers. They are 100% mandatory.... Sep 9 2020, 08:55 AM
billh1963 I'll throw out another possibility....
One da... Sep 9 2020, 09:02 AM
mburkhart
One d... Sep 9 2020, 09:39 AM
VaccaRabite
Anyw... Sep 9 2020, 09:46 AM
stugray
One d... Sep 13 2020, 10:29 AM
VaccaRabite The difference between the 17mm and the 19mm is on... Sep 9 2020, 09:35 AM
mburkhart
Did you pull the carpet and the pedal plywood and... Sep 9 2020, 11:51 AM
Did you pull the carpet and the pedal plywood an... Sep 9 2020, 12:33 PM
Craigers17 I did this a few months ago. I used this advice b... Sep 9 2020, 01:47 PM
mburkhart Well it looks like the caliper is the culprit. Br... Sep 12 2020, 02:57 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 12 2020, 06:50 PM
stugray
@[url=http://www.914world.com/bbs2/index.php?show... Sep 13 2020, 10:32 AM
Mikey914 I know we are making more now and may be able to l... Sep 12 2020, 09:49 PM
porschetub As far as failure. If there are not any apparent l... Sep 13 2020, 01:56 PM
sixnotfour
Old brake fluid increases the diagnoses.. Sep 13 2020, 12:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th April 2026 - 02:53 AM |
