> Any D Jet experts in Seattle?
Robson51
post Sep 5 2020, 12:00 PM
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money?
TIA
914werke
post Sep 14 2020, 03:22 PM
QUOTE(Robson51 @ Sep 14 2020, 10:42 AM) *
Rechecked the MPS with a better vacuum gauge. It will not hold vacuum, so is being sent out for repair.
A bad MPS will do it. (IMG:style_emoticons/default/headbang.gif)
Rand
post Sep 14 2020, 03:44 PM
Cross Member
QUOTE(914werke @ Sep 14 2020, 02:22 PM) *
THIS is why i asked you to pull the hose from the MPS and report the difference. (IMG:style_emoticons/default/headbang.gif)
Some clues point to obvious and when it only takes SECONDS to test....
Robson51
post Sep 15 2020, 03:43 PM
QUOTE(Rand @ Sep 14 2020, 02:44 PM) *
Actually, it died when I did that. The leakdown takes a good minute to go to zero.
Rand
post Sep 15 2020, 07:11 PM
Cross Member
QUOTE(Robson51 @ Sep 15 2020, 02:43 PM) *
Sorry about that, I took it too literal when you said it won't hold a vacuum. Holding for a minute isn't as bad as it sounded, and since it died when you pulled the hose it also shows it was holding some vacuum. Sounds like there's more going on than just the MPS diaphragm. Good luck, you're in good hands.
Bleyseng
post Sep 16 2020, 08:21 AM
Aircooled Baby!
QUOTE(Rand @ Sep 15 2020, 06:11 PM) *
That just means the diaphragm is cracked halfway and not completely blown apart.
Robson51   Any D Jet experts in Seattle?   Sep 5 2020, 12:00 PM
sixnotfour   @914werke millcreek area   Sep 5 2020, 12:02 PM
Robson51   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 5 2020, 12:36 PM
Jett   Redmond European... Monty has the right equipment ...   Sep 5 2020, 02:12 PM
Bleyseng   What's wrong with it? I am on Beacon Hill. Ric...   Sep 5 2020, 03:03 PM
rjames   I just spent the last 2 summers get my DJet back i...   Sep 5 2020, 03:17 PM
Robson51   I just spent the last 2 summers get my DJet back ...   Sep 5 2020, 04:28 PM
Bleyseng   First- Is the Cylinder Temp sensor good? Test it p...   Sep 5 2020, 05:26 PM
Robson51   First- Is the Cylinder Temp sensor good? Test it ...   Sep 5 2020, 05:57 PM
914werke   Sorry, been convalescing. But try & help anywa...   Sep 5 2020, 05:56 PM
Bleyseng   MPS number is 043? ECU number is ending in 044? S...   Sep 5 2020, 06:46 PM
Robson51   MPS number is 043? ECU number is ending in 044? ...   Sep 5 2020, 07:32 PM
Robson51   MPS number is 043? ECU number is ending in 044? ...   Sep 7 2020, 12:18 PM
Bleyseng   "ECU is 11 clicks from full stop left" D...   Sep 5 2020, 07:12 PM
Robson51   "ECU is 11 clicks from full stop left" ...   Sep 6 2020, 09:07 AM
Bleyseng   "ECU is 11 clicks from full stop left...   Sep 6 2020, 04:53 PM
Robson51   [quote name='Robson51' post='2848954' date='Sep 6...   Sep 8 2020, 02:31 PM
mightyohm   Cold start should not be operating this time of ye...   Sep 6 2020, 06:26 PM
Robson51   Cold start should not be operating this time of y...   Sep 7 2020, 01:27 PM
rjames   Did the car ever run well with the parts it has in...   Sep 7 2020, 11:04 AM
Robson51   Did the car ever run well with the parts it has i...   Sep 7 2020, 01:26 PM
rjames   Very likely it needs to be tuned for your car. T...   Sep 7 2020, 02:48 PM
Rand   Bypass the CSV, you don't need it and it's...   Sep 7 2020, 02:50 PM
Robson51   for an update-car is running and getting better al...   Sep 14 2020, 11:42 AM
Bleyseng   I think I have a good used one if you want for rea...   Sep 14 2020, 02:10 PM
Robson51   I think I have a good used one if you want for re...   Sep 15 2020, 03:50 PM
914werke   Rechecked the MPS with a better vacuum gauge. It...   Sep 14 2020, 03:22 PM
Rand   [quote name='Robson51' post='2851240' date='Sep 1...   Sep 14 2020, 03:44 PM
Robson51   [quote name='Robson51' post='2851240' date='Sep ...   Sep 15 2020, 03:43 PM
Rand   Actually, it died when I did that. The leakdown ...   Sep 15 2020, 07:11 PM
Bleyseng   Actually, it died when I did that. The leakdown...   Sep 16 2020, 08:21 AM
Rand   [quote name='Rand' post='2851653' date='Sep 15 20...   Sep 16 2020, 04:04 PM
thelogo   Stop me if you've heard this one ( i know you ...   Sep 16 2020, 04:18 PM
Bleyseng   Stop me if you've heard this one ( i know you...   Sep 16 2020, 07:03 PM
rjames   @Rand Correct me if I'm wrong, but I don...   Sep 16 2020, 04:35 PM
Rand   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 16 2020, 04:49 PM
Rand   logoman loves to stir the carb pot. I get it, it...   Sep 16 2020, 07:17 PM
Bleyseng   My has run so well since 1997 I can't bring my...   Sep 16 2020, 08:35 PM
Rand   My has run so well since 1997 I can't bring m...   Sep 16 2020, 08:39 PM
bobforman   Try George at Porbug in Edmonds.   Sep 16 2020, 11:39 PM
Robson51   Try George at Porbug in Edmonds. Thanks-that...   Sep 17 2020, 03:23 PM
Bleyseng   There is also Denny Akers Porsche on Capital Hill.   Sep 17 2020, 09:01 AM
rjames   @Robson51 Hopefully the rebuilt and recalibrated ...   Sep 17 2020, 12:04 PM
- Lo-Fi Version Time is now: 26th November 2026 - 02:23 PM
