> 914-6 Conversion Shift Linkage Question, (Firewall Back)
RichPugh
post May 10 2020, 04:29 PM
So... the engine is in (I’m using the NaroEscape -6 front mount) and, seeming because of the mount, it sits lower than stock. The Patrick Motorsport -6 shift linkage rod I intended on using, wont work. It interferes with the engine case and doesn’t seem to have a workaround. If the engine were 1/4” - 1/2” higher at the firewall, it looks like it would slip in, but alas, the engine is not going anywhere, lol.
I’m tempted to just bend the PMS bar end upward (maybe a couple inches from where it goes from the narrow shank to the bar rod) to give it the clearance but that would change the angle it goes into the rear bushing and connects to the shift lever... so I figured I’d ask if anyone else had an issue with the bar hitting the engine case and any options I might have. I’m OK with modding the old -4 rod too. Might be worth a shot but figured I’d ask here first.
The other threads I found look like the stock rod modded is the move.
Thanks
RichAttached Image
live free & drive
post Sep 21 2020, 09:55 AM
I'm dealing with this same issue right now. I had already welded in the Naro mounts before understanding their issues.
I recently got a hold of a Patrick mount which looks to mount the engine in the proper place according to some measurements taken by another member. The Patrick cross bar can be swapped in, as the spacing is nearly the same. It raises the motor .62" ,which is good, but it also pushes the motor .60" closer to the firewall; which with the Naro mount already being .5" closer puts the engine 1.1" closer to the firewall altogether bringing the axles and trans mounts that much further forward, potentially causing more issues.
I have decided to modify the Naro cross-bar by welding on some machined/threaded offset extensions which will push the bar up .75" hopefully placing everything in proper alignment (although still .5" forward).
Another note is that neither the Naro nor Patrick mounts were anything close to flat at the engine interface- both being out about .125". I was able to "adjust" the Naro mount to flat by percussion persuasion and light lapping, but due to the design the Patrick mount is non adjustable.
There are aspects of each companies engine mount that I think are better than the others solutions, but neither are perfect.
RichPugh   914-6 Conversion Shift Linkage Question   May 10 2020, 04:29 PM
Coondog   I would call James Patrick on Monday. He had to be...   May 10 2020, 04:49 PM
porschetub   So... the engine is in (I’m using the NaroEscap...   May 10 2020, 05:37 PM
Mark Henry   Good job I also built my own shift rod, this is th...   May 11 2020, 05:59 PM
roblav1   My conversion side shifter mechanism was a straigh...   May 11 2020, 07:59 PM
Retroracer   I purchased the PMS shift rod for my -6 conversion...   May 11 2020, 10:04 PM
sixnotfour   Looks like they are needing some dimensional guida...   May 11 2020, 10:24 PM
sixnotfour   :blink:Naro needs to post about this..Most want fa...   May 17 2020, 11:17 AM
RichPugh   Thanks everyone. Just getting back around to this ...   Sep 20 2020, 06:43 PM
RichPugh   Maybe something like this...   Sep 20 2020, 06:44 PM
mb911   I had the same issue with a conversion I did for a...   Sep 21 2020, 05:39 AM
JOEPROPER   I had the same issue with a conversion I did for ...   Sep 21 2020, 07:20 AM
mb911   I would highly recommend it .. I personally have n...   Sep 21 2020, 07:35 AM
RichPugh   I would highly recommend it .. I personally have ...   Sep 21 2020, 08:13 AM
PanelBilly   I’m using my oem rod but rotated it so it clear...   Sep 21 2020, 08:47 AM
live free & drive   I'm dealing with this same issue right now. I...   Sep 21 2020, 09:55 AM
mb911   I do have a fixture to modify the stock rod if you...   Sep 21 2020, 11:58 AM
RichPugh   https://youtu.be/62qQqz_GOT4   Sep 21 2020, 08:42 PM
RichPugh   I thought it was hitting one of the header pipes b...   Sep 21 2020, 08:46 PM
RichPugh   Anyone else using a stock -4 bar just clocked/re-i...   Sep 24 2020, 11:27 AM
IronHillRestorations   You can't use a stock 4 side shift bar as is i...   Sep 24 2020, 12:05 PM
RichPugh   You can't use a stock 4 side shift bar as is ...   Sep 24 2020, 01:34 PM
mb911   You can't use a stock 4 side shift bar as is...   Sep 24 2020, 02:32 PM
gandalf_025   I have a friend that bought the Naro mount and de...   Sep 24 2020, 12:41 PM
JOEPROPER   This is disappointing. Maybe the Naro Racing peop...   Sep 24 2020, 02:28 PM
live free & drive   I don't know if you all have seen these posts ...   Sep 24 2020, 04:43 PM
RichPugh   I don't know if you all have seen these posts...   Sep 24 2020, 08:50 PM
nditiz1   @richpugh I have a modified shift shaft that Ben ...   Sep 24 2020, 06:18 PM
RichPugh   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 24 2020, 08:43 PM
JmuRiz   I’m sure I’ll send my /4 rod to Ben....maybe i...   Sep 24 2020, 09:39 PM
nditiz1   I will be around all weekend. Shoot me a PM with ...   Sep 24 2020, 09:42 PM
mb911   Rich and Nick the only issue with using that linka...   Sep 25 2020, 04:28 AM
RichPugh   Rich and Nick the only issue with using that link...   Sep 25 2020, 06:39 PM
RichPugh   So... Something like this would work. Ignore the ...   Sep 25 2020, 07:41 PM
nditiz1   Understood Ben. So do you have two jigs, one for ...   Sep 25 2020, 06:11 AM
mb911   Understood Ben. So do you have two jigs, one for...   Sep 25 2020, 07:26 AM
Tdskip   Oh boy - I was planning on welding in the Naro Mo...   Sep 25 2020, 09:02 AM
mb911   Oh boy - I was planning on welding in the Naro M...   Sep 25 2020, 09:15 AM
RichPugh   Oh boy - I was planning on welding in the Naro ...   Sep 25 2020, 06:15 PM
Mark Henry   I made my own RJ copy mount*, I mounted the bulkhe...   Sep 25 2020, 10:09 AM
mb911   I made my own RJ copy mount, I mounted the bulkhe...   Sep 25 2020, 10:14 AM
Mark Henry   That is what I did with my 1st conversion.. This...   Sep 25 2020, 10:21 AM
RichPugh   Lesson learned. Listening to the manufacturers ...   Sep 25 2020, 06:32 PM
porschetub   Lesson learned. Listening to the manufacturers...   Oct 2 2020, 05:30 PM
Mark Henry   I mounted the bulkhead mount to the motor, then I...   Sep 30 2020, 10:55 AM
RichPugh   Did you have to relocate the rear brake bias uni...   Sep 30 2020, 11:13 AM
Mark Henry   Did you have to relocate the rear brake bias un...   Sep 30 2020, 11:29 AM
Steve   Did you have to relocate the rear brake bias u...   Sep 30 2020, 11:53 AM
Mark Henry   AFAIK vellios (rip) designed the mount first and...   Sep 30 2020, 12:35 PM
nditiz1   @tdskip try to return the naroscape if you can an...   Sep 25 2020, 12:16 PM
JOEPROPER   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 25 2020, 01:01 PM
RichPugh   :thumbsup:   Sep 25 2020, 06:33 PM
RichPugh   Rich and Nick the only issue with using that link...   Sep 28 2020, 03:45 PM
mb911   Rich and Nick the only issue with using that lin...   Sep 28 2020, 04:10 PM
gandalf_025   This is what they did to the 914-6 race cars back ...   Sep 28 2020, 04:05 PM
RichPugh   This is what they did to the 914-6 race cars back...   Sep 28 2020, 07:56 PM
mb911   http://www.914world.com/bbs2/index.php?sho...39906...   Sep 28 2020, 06:56 PM
RichPugh   http://www.914world.com/bbs2/index.php?sho...3990...   Sep 28 2020, 07:52 PM
Tdskip   Great discussion. Sounds like the Naro mount need...   Sep 28 2020, 10:10 PM
RichPugh   Great discussion. Sounds like the Naro mount nee...   Sep 29 2020, 10:10 AM
mb911   Great discussion. Sounds like the Naro mount ne...   Sep 29 2020, 10:15 AM
RichPugh   I was considering adding a new 2nd "bar...   Sep 29 2020, 12:52 PM
RichPugh   Here's just a couple pics showing exactly wher...   Sep 29 2020, 12:24 PM
Tdskip   Why couldn’t we “just” do this? Add thickne...   Sep 30 2020, 06:17 AM
Tdskip   One other way to go it is to add spacers on the mo...   Sep 30 2020, 06:21 AM
RichPugh   One other way to go it is to add spacers on the m...   Sep 30 2020, 09:54 AM
Tdskip   One other way to go it is to add spacers on the ...   Sep 30 2020, 10:24 AM
mb911   [quote name='RichPugh' post='2855549' date='Sep 3...   Sep 30 2020, 10:45 AM
RichPugh   Welding the ears in 3/4" higher would/could...   Sep 30 2020, 11:09 AM
JOEPROPER   Maybe you could weld to the front of the U shaped ...   Sep 30 2020, 11:22 AM
RichPugh   Maybe you could weld to the front of the U shaped...   Sep 30 2020, 01:37 PM
ClayPerrine   Unfortunately, all of our parts are not produced b...   Sep 30 2020, 11:51 AM
Tdskip   Like this - with the red being thicker steel to he...   Oct 1 2020, 12:31 PM
mb911   Like this - with the red being thicker steel to h...   Oct 1 2020, 06:19 PM
sixnotfour   here is the numbers to help http://www.914world.co...   Oct 2 2020, 09:09 PM
Tdskip   here is the numbers to help [url=http://www.914wo...   Oct 3 2020, 08:51 AM
RichPugh   First off... Definitely more vibration. It's...   Oct 3 2020, 03:33 PM
Tdskip   First off... Definitely more vibration. It...   Oct 3 2020, 03:55 PM
mb911   For those not yet having installed one I would sug...   Oct 3 2020, 09:15 AM
live free & drive   The Naro mount has Delrin bushings - the Patrick m...   Oct 3 2020, 04:50 PM
Tdskip   Interesting - I just welding the Naro mount in 3/4...   Oct 24 2020, 03:09 PM
RichPugh   Maybe the slant of the firewall is enough to bette...   Oct 24 2020, 03:27 PM
Tdskip   Maybe the slant of the firewall is enough to bett...   Oct 24 2020, 03:59 PM
JOEPROPER   @RichPugh How did you make out with that engine m...   Nov 6 2020, 10:55 AM
RichPugh   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 11 2020, 10:58 AM
RichPugh   UPDATE: Sent the car to Lufteknic in Richmond 2 ye...   May 18 2024, 05:30 PM
- Lo-Fi Version Time is now: 26th November 2026 - 10:27 AM
