Engine lid bracket repair/install |
JamesJ |
Sep 19 2020, 01:38 PM
Member Group: Members Posts: 223 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Looking for someone here that can perform this job or give a recommendation of someone qualified. My driver side engine lid bracket is loose and it is causing my engine lid to swing open when driving. Strange thing is that it not that loose, but perhaps it doesn’t take much movement to cause the rear lid latch to release the lid. I have attempted to adjust the latch, but that has not worked out. I purchased two new brackets, but need someone to take a look at it first to determine whether it would be best to reweld the original bracket, or install a new patch panel, or to install a new bracket(or perhaps do both sides), or any combination of these.
I have researched previous threads on this topic that have provided good insight on this issue, but since I am not a welder I prefer to have someone with experience evaluate and perform the work. I am in the San Francisco Bay Area. Thanks, James. |
GregAmy |
Sep 19 2020, 01:42 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
You sure it's the bracket? Mine used to do that, but it was because the chassis was flexing and the latch pin was pulling forward and out of the latch.
I resolved that by cutting and bending a 6mm(?) bolt that allowed the pin end to extend further into the catch. No more bump-and-swing. |
Olympic 914 |
Sep 21 2020, 03:38 PM
Group: Members Posts: 1,673 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
You sure it's the bracket? Mine used to do that, but it was because the chassis was flexing and the latch pin was pulling forward and out of the latch. I resolved that by cutting and bending a 6mm(?) bolt that allowed the pin end to extend further into the catch. No more bump-and-swing. Or you could put spacers (washers) between the latch and the mount to move it towards the bent latch pin. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:25 AM |
