Engine lid bracket repair/install |
JamesJ |
Sep 19 2020, 01:38 PM
Member Group: Members Posts: 223 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Looking for someone here that can perform this job or give a recommendation of someone qualified. My driver side engine lid bracket is loose and it is causing my engine lid to swing open when driving. Strange thing is that it not that loose, but perhaps it doesn’t take much movement to cause the rear lid latch to release the lid. I have attempted to adjust the latch, but that has not worked out. I purchased two new brackets, but need someone to take a look at it first to determine whether it would be best to reweld the original bracket, or install a new patch panel, or to install a new bracket(or perhaps do both sides), or any combination of these.
I have researched previous threads on this topic that have provided good insight on this issue, but since I am not a welder I prefer to have someone with experience evaluate and perform the work. I am in the San Francisco Bay Area. Thanks, James. |
JamesJ |
Sep 22 2020, 04:25 PM
Thank you all for the great suggestions/recommendations. I'll attempt to leave the bracket in place and use the recommended larger bolt and/or washers. If not, then I'll try to make the bracket more secure with some welding or weld in a new bracket. Once secure, I'll address the latch pin after that. You guys are great!
Lo-Fi Version | Time is now: 9th June 2024 - 03:11 PM |
