Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
I pulled the fuel tank out of the Fresno 914 because it sat for 20+ years, and I’m not sure if it was properly drain first or if the fuel just all evaporated. Seems like a bad idea to just dump gas in it so it’s at a radiator shop being tested and cleaned out.
That, however, leaves me without a fuel tank to get the car fired up and I happen to have one that was dipped but is unfinished. Since the tanks are identical and not stamped I can swap them out without the car sliding into the “non-numbers matching “category. Doesn’t really matter because it’s a bit of this and get to that car since I bought it as a roller anyway. Ha. So-how do you guys like to finish and recommend repairing the fuel tank. It looks like the tanks were originally just painted and assembled into the car without any interior lining to the tank, correct? Do the same thing or do you recommend getting them finished differently? Thanks! |
willieg |
Member ![]() ![]() Group: Members Posts: 133 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California ![]() ![]() |
I used the Eastwood tank sealer and etcher. The sealer dries as hard as a rock and is reputed to seal small holes also. Once you coat the inside of your tank with the sealer, you drain the excess. I put some of the excess into an old coffee can as a test. If the coffee can is any indication, my gas tank is going to be just fine.
Lo-Fi Version | Time is now: 11th June 2024 - 12:40 AM |
