| Blown59 |
Sep 23 2020, 07:05 PM
Member ![]() ![]() Group: Members Posts: 70 Joined: 21-July 19 From: St Louis Member No.: 23,315 Region Association: None |
I dont even know where to begin...
I just recently completed my first "major" restomod or refurbishmod and while I did a LOT of work, it may not be to the level that some of you guys have done. (some of you guys do an incredible job and mine pales in comparison) But this is a car built the way I wanted it. While its not 100% complete to my liking, (still wanted to recover my seats and rebuild the engine this winter) it is to a driveable state now. The engine does leak some oil on the heat exchangers because the pushrod seals leak as do the valve cover gaskets, I havent worried about fixing them since I planned on my winter rebuild. Here is where things are getting difficult for me, I feel as if I'm at an impasse... A couple of other P cars have presented themselves to me, one of which is another 914 , that I dont want to pass up on. My dilemma is to sell this current build as is without building the 2270 and keeping the new 914 I'm about to acquire... Or resell the one ive committed to purchase. Unfortunately, I dont have the room for them both. The ability to store one of them at this time or even within the near future is also out of the question. I also feel as if I'm having withdrawls, not having a "project" to work on. I really enjoyed this one and want to dig into another. It's almost become an addiction for me now that ive undertaken something of this sort already. So, this leads me to realize selling my restomod may be something I have to seriously consider. Being that the car was built for me and my liking, I'm not sure how much interest there is in it. Also, because it is more of a restomod, what kind of value would the 914 community place on this? The floor pans were stripped to bare metal on the interior side. Steel flares welded in. Car sprayed in epoxy. Interior, underside, front and fenderwells coated with U-Pol Raptor Liner. Highbuild primer and base/clear applied. Engine compartment not yet refinished. Front suspension rebuilt and coated with Por15, all new bushings, turbo tierods. Struts/hubs from 911t have been refurbished/painted. New inserts and new bearings installed. Front M calipers have been rebuilt with new pistons and rebuild kit. Steering rack cleaned and refurbished, new puck, lube, etc. Traling arms removed and stripped and coated with Por15, 914 inner CVs rebuilt, outer 944 CVs, boxter hubs, with 916 rotors. New rear Bilstein struts with new 100lb 916 springs installed. Entire shift assembly removed, cleaned/stripped/repainted and lubes. All new shifter/linkage bushings/guides replaced. Headlight assemblies replaced with a gently used (almost NOS 911 bits). H4 housings with LED bulbs. Gauges have LED bulbs as well. New clear signal lenses. All Gaskets/rubber replaced with 914 rubber parts (Doors, targa, trunks front/rear). New windshield and trim. Seatbelts disassembled/cleaned and now properly retract. Custom fiberglass leather covered center console. Any part/bolt needing replaced was. Anything worth salvaging or in good usable condition was kept. Rear trunk lock removed and covered with a flat emblem trunk straps installed in homage to GT cars. Front trunk cable removed along with factory latch lock. Hood release kept and used in conjunction with a fabricated latch catch as safety measure. Front hood has 4 traditional hood pins in respective locations. I'm sure there is more that is "slipping my mind" at the moment, but these are some of the main things I can recall at the moment. 765] Attached thumbnail(s) |
| infraredcalvin |
Sep 23 2020, 09:02 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,754 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
That’s certainly a good start for someone to continue to work with, the issue you have is the big money shot items are left to complete, The motor and final paint, are some very expensive items. Put a price on it that you absolutely have to get in order to recoup some of your efforts and that you might need to put into the “new project”. If it sells than it was meant to be. Bets are you have way more into this than somebody is willing to spend...
BTW, at the right price, and pending pics mentioned above, I’d be tempted... |
Blown59 914 Restomod and Heavy Heart... I'm torn... Sep 23 2020, 07:05 PM
IronHillRestorations Sounds and looks like you should keep it. If you ... Sep 23 2020, 08:36 PM
bandjoey Dance with the One Who Brung Ya. Keep your car. ... Sep 23 2020, 09:43 PM
ndfrigi Beautiful job you have than to that car. Why not ... Sep 24 2020, 12:17 AM
Mikey914 I'd keep it at least for now. You may not have... Sep 24 2020, 12:30 AM
IronHillRestorations The only thing I'd add is that for me a 2270 4... Sep 24 2020, 06:20 AM
Blown59 Everyones input has already resonated within me at... Sep 25 2020, 05:32 PM
Tdskip Your build isn’t so personalized that it won’t... Sep 25 2020, 07:51 PM
PanelBilly Put an ad in you"re local PCA regions Faceboo... Sep 25 2020, 08:24 PM
ri914 That is a very nice build. I am sure it will sell ... Sep 25 2020, 08:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th June 2026 - 12:51 PM |
