74ravenna |
Member ![]() ![]() Group: Members Posts: 472 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States ![]() ![]() |
After watching Ian's video of rear shock replacement (Thanks Ian) I did it myself this morning.
Thing is, when Ian did it his Control Arm dropped noticeably after taking off the top nut. Mine didn't, they stayed put and it took a fair amount of downward pressure to get them to drop low enough to clear the shock. So I suspect mine need a little attention. A little history about the car.....it hasn't been on the road in 37 years. Any tips are greatly appreciated Thanks Steve |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,493 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
That's good actually. The rubber bushing doesn't rotate thus the arm will stay at 'neutral'.
If it just fell then either the bushings have split (bad) or you have poly bushings or other aftermarket. |
74ravenna |
That's good actually. The rubber bushing doesn't rotate thus the arm will stay at 'neutral'. If it just fell then either the bushings have split (bad) or you have poly bushings or other aftermarket. Oh good. I thought maybe due to inactivity they may have bound. Thanks for your help. Steve |
Lo-Fi Version | Time is now: 16th July 2025 - 12:41 PM |
