> Control Arm maintenance, Welcoming advice.
74ravenna
post Sep 29 2020, 11:58 AM
After watching Ian's video of rear shock replacement (Thanks Ian) I did it myself this morning.
Thing is, when Ian did it his Control Arm dropped noticeably after taking off the top nut.
Mine didn't, they stayed put and it took a fair amount of downward pressure to get them to drop low enough to clear the shock.
So I suspect mine need a little attention.
A little history about the car.....it hasn't been on the road in 37 years.
Any tips are greatly appreciated
Thanks
Steve
barefoot
post Sep 30 2020, 07:31 AM
If you're into removing the control arms, here's my trick to get them back in exact position when re-mounting them.
I drilled a 1/4" hole up thru the outer mount bracket up into the body so I could pin the location exactly on re-assembly. Don't forget to ue the same number off shims on each side also. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 16th July 2025 - 12:18 PM
