| simonjb |
Oct 4 2020, 03:19 PM
KiwiMan ![]() ![]() ![]() Group: Members Posts: 574 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States
Hi,
So I am installing a set of insulator gaskets to reduce the heat to the carbs and cut back on fuel boiling after a drive. I ordered the kit from partsklassic. Seemed good until I went to instal the gaskets that go either side of the 44 Insulator. The gaskets are smaller than the insulator - 41 - see pics below. I've sent them an email. But in the meantime I've looked for 44 size and most places have a gasket for 40/44 IDF which implies they use the same gasket for 40 or 44. Can this be correct? ![]() ![]() ![]() |
| simonjb |
Oct 4 2020, 05:33 PM
These fit between the Manifold and the carbs....Cutting these is a PITA, so I found some weber 44's online...Thanks
simonjb Weber 44 IDF insulators Oct 4 2020, 03:19 PM
rhodyguy If the stud holes work, trim to fit. Not uncommon.... Oct 4 2020, 04:05 PM
porschetub They look more like 911 intake gaskets ?,sorry to ... Oct 4 2020, 04:26 PM
rhodyguy Something like this in between the carbs and the i... Oct 4 2020, 07:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 05:58 PM |
