burlybryan |
Member ![]() ![]() Group: Members Posts: 128 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None ![]() ![]() |
Howdy. Adjusted the valves for the first time on my new-ish to me carbed '74 1.8.
I noticed that the interface between the valve stem and adjuster on the #2 exhaust valve shows some rust or discoloration. The previous owner had the engine converted to carbs and the crank ventilation trap is plumbed to a bung that was welded to the valve cover right next to this valve. Could the water vapors being introduced to this area cause corrosion? Is it something to be concerned about? Thanks! Bryan Attached thumbnail(s) ![]() |
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
Just to be sure, do you have the carb throttles wide open when doing the compression test? IF not you will see a significantly lower compression reading.
Lo-Fi Version | Time is now: 4th June 2025 - 06:45 PM |
