Break in Compression 2 Liter, Valve Adjust/Duration/Lift...etc |
newdeal2 |
Dec 20 2004, 05:13 PM
Unregistered |
OK, here's the scoop. I have the car running [the infamous 2 liter D jet re build] reasonably well. I re did the compression test [all plugs out/Throttle open]and it ranges from 120 -140.
I have been told that the WebCam [by Raby] having a longer duration and better lift will throw numbers off since it is intended to improve the mid range. I have also noted from various sources that it could be a simple valve adjustment that will bring the numbers closer. Am I getting too anal here? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Jake Raby |
Dec 20 2004, 07:17 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Have the rings had time to seat yet??
If not that could make a big difference. What static CR did you set it at?? |
Lo-Fi Version | Time is now: 7th June 2024 - 05:43 AM |
