| Tdskip |
Oct 9 2020, 07:33 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
I've heard it both ways (nod to any Psych fans out there), and preferred orientation of the linkage?
Thanks! |
| rhodyguy |
Oct 9 2020, 11:32 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
On the front. PITA standing on your head dialing the carbs in when installed on the rear. Check out the one from TriadWest. While it looks similar, there are vast differences. +, it comes WITH a cable bracket. No fabrication required. Only other options for a set of carbs is a pulley system or center pull.
Tdskip IDF Weber with hex bar - linkage towards front or rear of car? Oct 9 2020, 07:33 AM
Mark Henry
... preferred orientation of the hex bar linkage?... Oct 9 2020, 07:45 AM
Tdskip
... preferred orientation of the hex bar linkage... Oct 9 2020, 08:11 AM
914werke ... preferred orientation of the hex bar linkage... Oct 9 2020, 09:28 AM
Spoke I had the bar connected towards the rear but the l... Oct 9 2020, 12:08 PM
Tdskip Thanks for the responses - just need to get this o... Oct 9 2020, 01:14 PM
ndfrigi
Thanks for the responses - just need to get this ... Oct 9 2020, 01:29 PM
Ansbacher I have a hex bar linkage and am confused by this w... Oct 9 2020, 02:25 PM
rhodyguy The forward side of the carbs.
Throw the cross ba... Oct 9 2020, 02:41 PM
Ansbacher I think if I tried to put it in front of my carbs,... Oct 9 2020, 02:55 PM
nditiz1 Towards the front of the car. If you are just try... Oct 10 2020, 11:35 AM
Tdskip Thanks for all of the responses. I just need to ge... Oct 10 2020, 02:17 PM
Gint A lot of it depends on what other junk is in your ... Oct 10 2020, 03:00 PM
Ansbacher So...to do a swap from front to back or vice-versa... Oct 10 2020, 06:54 PM
Tdskip
So...to do a swap from front to back or vice-vers... Oct 11 2020, 07:06 AM
Gint Carbs swapped, no. You would have to take the end... Oct 11 2020, 12:35 PM
Tdskip
Carbs swapped, no. You would have to take the en... Oct 11 2020, 12:44 PM
Gint Carbs swapped, no. You would have to take the end... Oct 11 2020, 01:07 PM
Gint Ok, whatever works for you. That would mean your ... Oct 11 2020, 12:50 PM
Tdskip Thanks for all of the responses and discussion, in... Oct 11 2020, 02:42 PM
Gint Info, exchange of information and ideas never hurt... Oct 11 2020, 02:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 02:40 AM |
