JamesJ |
Member ![]() ![]() Group: Members Posts: 239 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California ![]() ![]() |
Hello All,
I am researching a rear coilover setup for my car. I don't plan to do any auto crossing, but would like a nice canyon carver. From previous threads on this site, it seems that 140/150 lb. rear spring would be good as well as removing my rear sway bar, installing a larger front sway bar(perhaps one or two sizes up from stock), and keeping my stock torsion bar. I currently have Koni sport shocks all around. It appears that my left rear shock is leaking, so I am thinking to go ahead and get two new rear shocks. If I get Bilsteins for the rear, should I change out my front shocks to match? Do you prefer Koni adjustable or Bilsteins? Is the damping control of the Koni necessary for a street car? Any experience with the different coilover setups from Ground Control, Elephant Racing, or Tarett Engineering? For springs, do you prefer Eibach or Swift or another brand? I am not sure why, but Elephant Racing uses a 2.5” rear spring, while Tarett Engineering uses a 2.25” rear spring-both are Eibachs. I don't think I will need a helper spring for street use. Any thoughts would be appreciated. Thank you. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,254 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
You’ve proposed completely changing the car in terms of hardware, cost, and most importantly the handling balance. The 914 is already a competent canyon carver in stock trim. What are you trying to achieve with all the parts swaps? |
Lo-Fi Version | Time is now: 1st August 2025 - 04:12 AM |
