JamesJ |
Member ![]() ![]() Group: Members Posts: 239 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California ![]() ![]() |
Hello All,
I am researching a rear coilover setup for my car. I don't plan to do any auto crossing, but would like a nice canyon carver. From previous threads on this site, it seems that 140/150 lb. rear spring would be good as well as removing my rear sway bar, installing a larger front sway bar(perhaps one or two sizes up from stock), and keeping my stock torsion bar. I currently have Koni sport shocks all around. It appears that my left rear shock is leaking, so I am thinking to go ahead and get two new rear shocks. If I get Bilsteins for the rear, should I change out my front shocks to match? Do you prefer Koni adjustable or Bilsteins? Is the damping control of the Koni necessary for a street car? Any experience with the different coilover setups from Ground Control, Elephant Racing, or Tarett Engineering? For springs, do you prefer Eibach or Swift or another brand? I am not sure why, but Elephant Racing uses a 2.5” rear spring, while Tarett Engineering uses a 2.25” rear spring-both are Eibachs. I don't think I will need a helper spring for street use. Any thoughts would be appreciated. Thank you. |
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
KISS. Replace broken shock with like item. Install 140# rear springs.
fwiw, I am in the side of "front and rear sways". I've had several over the years and always liked that set up. I know others are firmly in the "front only" sway bar camp. Its almost as volatile as asking what oil do you recommend! I am also of the opinion that if you upgrade the rear springs you should upgrade the front match. I'd be inclined to swap out front torsion bars for stiffer ones to match the new roll rate of the rear springs. |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 959 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
Whether you need a rear sway depends on what you have in the front. What are the front torsion bar and swaybar sizes?
Lo-Fi Version | Time is now: 1st August 2025 - 04:06 AM |
